I have developed a whistling noise under light acceleration. I first noticed it a few months ago but it was quiet enough that i didn't really look into it. Fast forward to a few days ago and I just installed the ECS Tuning Luft-Technik intake system and it has become much more noticeable with the open element filter.
I have searched but nothing really seems to match up quite with what I am experiencing.
It happens:
- In every gear
- Only when my boost gauge reads between 10 in/hg and 3psi (above or below that it doesn't make the noise)
- It is not RPM dependent. As long as I am in the vacuum/boost range I said above, it makes the same noise regardless of RPM
- Makes the noise in both stock mode and 91oct
- My best description of the sound would be a tea kettle right as it starts to boil/whistle
The car in question is a 2011 2.0T quattro with APR stage 1, ECS luft-technik intake. My first though was a bad DV? or maybe a bad PCV? I had a DV go out on my FSI VW GTI but it didn't sound like this.
Thanks in advance.
