I did some searching but didn't come up with much that seemed to fit my issues. My S4 (B6, 2005) has a strange "shaking" feeling when at low idle. It will run perfectly smoothly, then every 3 or 4 seconds will kind of shudder almost like it is misfiring. However, actively logging in VCDS while it is doing it shows 0 misfire count on all cylinders. Also, it has brand new coils, several new coil connectors, new plugs, etc as I just recently did a bunch of work on it.
As soon as you touch the gas, the shaking stops. When you first start the car cold and it sits at high idle around 1000 RPM, it is butter smooth. Only when the idle settles down to 750 or whatever it is, does it begin the odd, long-interval shuddering. The car pulls hard in all gears without vibration, and pushing in the clutch makes 0 difference, so flywheel issues don't seem logical either. However, the shaking is enough to concern me, and after all this car has done to me, I'm nearly paranoid driving it half the time.
I occasionally notice a similar but more fast-paced shudder when loading up the engine (such as accelerating on a hill in too high a gear around 2500 RPM) but I'm suspicious of a bad CV on that as one of my CV's somehow expelled all its grease without tearing the boot, halfway through a 2000 mile road trip, so it went quite a while nearly dry. The fact that it doesn't howl is testament to the quality of the OE axles. In any case, this has nothing to do with issues at idle.
Any ideas? Could motor mount problems manifest themselves in this fashion? The mounts are likely original, although my snub is new.
Thanks,
Alex
