Here are some pics of remaining parts, feel free to PM me if you see anything you need/want. Shipping/PP fees extra. If you happen to be in the greater NYC area, I may be trying to put together a "delivery" trip in the near future.
Manual conversion package, most everything needed $350
transmission (with mount brackets/mounts, throw out bearing/arm), used clutch/flywheel/pp, front axles, shifter box (with boot and surround, linkages etc), pedal cluster (with clutch master, misc switches, brake and clutch pedals), clutch slave and lines, prop shaft, rear diff SOLD
Accessory bracket THROWN OUT
Front uprights with hubs, control arms, struts, springs, upper hats, ABS sensor. $25 per side Pending Payment
ABS pump $20
Serp belt tensioner SOLD
Alternator SOLD
Window motors $10 per
Brake booster $20
Brake MC/Res $20
PS res/lines $10
PS Pump $20
Fog Relay $10
Misc relays $5
Cam Position Sensor $10
AEB Power Output Stage from top of airbox $10
Windshield washer res/pumps/some lines $10
Front calipers/Carriers THROWN OUT
Nice used front rotors THROWN OUT
Trunk mounted CD Changer SOLD
Power Steering Lines $15
Windshield wiper motor/trans $15
Starter $20
Cruise control pump $15
Combi switch (wipers/lights/signals etc) $20
AEB valve cover $15
AEB Engine harness SOLD
Misc engine brackets/plates (turbo, I/M, front snubber from what I can readily identify in the pics) $5
A/C compressor mount bracket $5
Front bumper shocks $10 pair
Front core support $20
Front xpipe with snubber mount $10
Electric aux fan $10
Front license plate bracket $15
Side Mount Intercooler $20
Rear diff support bracket THROWN OUT
Bose amp $10
Central lock pump, worked, evidence of water on the pins $15
Silver driver side fender $25
Cactus green driver side fender, rusty lower THROWN OUT
Cactus green passenger fender, not perfect, light impact with deer left minor crinkling around the headlight opening... THROWN OUT
Passenger airbag THROWN OUT
Dual cup holder under armrest Pending Payment
PS/Water pump pulleys/main crank pulley $5 ea
Cruise control vacuum actuator with rod to throttle body $5
Non-aero wiper arms $5 pair
Motor mounts SOLD
Rear axles $15 each
Front axles (auto) SOLD
MAF -> Turbo hose with N75, pressure valve etc $20
Other boost hoses $10 ea
Engine cover SOLD
Airbox cover $10
Rear subframe w/swaybar, and brake lines control arms, rear uprights/hubs, shocks/springs (at least one broken), rear shock housings (one nice, one rusty crap) $30
Front shocks with springs SOLD
Front shocks with springs and upper hats/control arms SOLD
Rear shocks with springs, rusty housings, upper control arms SOLD
Downpipe/flex joint, lightly mangle rear pipe where the slip joint would have gone. SOLD
Front spindles/hubs w/ABS sensors and upper control arms $10
Loaded silver sedan doors (uppers/lowers/glass/motors/regs/handles/locks etc), no door panels $15
Probably more stuff lying around as well, this was just the stuff out in the open that I took quick pics of.
