Results 1 to 6 of 6
    Veteran Member Four Rings Tanzimur's Avatar
    Feb 21 2013
    97 Brilliant Black A4 B5 1.8T
    Warren, MI
    Exclamation Aeb 1.8T Exccesive Blow By
    Well long story short got done with a 550cc hybrid rs6 k04 swap on my stock internal a4 b5 1.8t. Long story short when i take off the pcv hose leading to the tip its blowing white smoke intone of the exhaust pretty much and i recently did a compression test come to find out all 4 cylinders were around 70psi lowest was 50psi cyl 4, did a wet test got the numbers to go up to 130psi all 4.
    Now this is my second 1.8t junkyard engine swapped in im pretty much building this one with all the goodies drop in rods etc. Just wanted to ask what do you guys think it could be at this point headgasket and or waaay too much blow by not enough compression to start the car easily...????
    Dec 10 2013
    Borden, Ontario, Canada
    Your rings are toast. That's why you have so much blow by
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    ^ nailed it
    Dec 10 2013
    ^I nail everything
    IG: 24_et
    Sold:
    RIP:
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    Atta boy
    Feb 21 2013
    Warren, MI
    Lol yup i knew it, just wanted a second opinion! thanks bruhs... well stay tuned for the build lmao shell be apart next week on the day off and pulled heading out to machine shop!
