Results 1 to 40 of 53
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Thumbs up Now Available: JHM B8/B8.5 Porsche (Brembo) 382MM Front Big Brake Kit
    JHMotorsports is pleased to introduce a low cost, 100% Bolt On, Front BBK (Big Brake kit) solution for your B8 A4-S4 A5-S5 that uses the popular Porsche Brembo 6-Piston Caliper, also commonly known as the 19Z!
    INCLUDES:
    2x - JHM 2-piece Lightweight Slotted Front Rotors
    2x - JHM Caliper Brackets with Mounting Hardware
    2x - BRAND NEW OEM Porsche (6-piston Brembo) Calipers
    2x - Stainless DOT Approved Brake Lines
    1x - Set of OE Pads Brake Pads
    1x - OEM Brake Pad Sensor (Driver Side Only)
    1x - Liter Pentosin DOT 4 Synthetic Brake Fluid
    INSTALLATION: This is a COMPLETE 100% bolt on Big Brake Kit for the B8 Chassis. This kit requires ZERO modifications, cuts, grinds, splices, etc. making installation quick and simple. NOTE: The stock Dust Shields will need to be removed for proper clearance
    OEM S4-S5 Rotors vs. JHM Lightweight Rotors (A4-A5 vehicles will yield greater results)
    -Rotor Weight: Stock = 23lbs(each), JHM = 24.1lbs(each) - Only 1lb heavier for a MUCH larger rotor
    -Rotor Cooling Air-gap: Stock = 11.5mm(.450"), JHM = 18.5mm(.728") - LARGER for better cooling
    -Rotor Cooling Center Fin Design: Stock = One Direction Airfoil (one side pumps the air from the inside out and the other side pumps the air from the outside in), JHM = Airfoil (side specific rotors that both pump the air from the inside out) - EQUAL EFFICIENCY for equal cooling
    -Rotor OD: Stock = 345mm(13.6"), JHM = 382mm(15.039") - 1.43" LARGER
    -Rotor Thickness: Stock = 30mm(1.18"), JHM = 34mm (1.33") - 4mm (.15") LARGER
    -Bolt pattern: - SAME (fits like an OEM rotor would)
    Why the Porsche Cayenne caliper?
    With its 6-piston design and MASSIVE brake pads it is a strong performer. Also it bolts right up to your spindles using our JHM CNC'd Caliper Brackets. All you need is the included bolts, brake lines and JHM rotors and you have a 382mm Big Brake Kit.
    Outer ring specs:
    We worked closely with a race brake manufacturer that supplies many NASCAR racers and a couple major brake kit companies. Due to their expertise we chose to have them build us the outer rings to our specs to fit the B8 Chassis. 12 attachment points for durability and strength.
    Center hat specs:
    We CNC machine the Aluminum center hats in house based on their recommended materials and thicknesses for durability. 12 attachment points for durability and strength. We also engrave JHM in them in 3 locations equal from each other, it looks clean and doesn't jump out or look tacky.
    Custom Caliper Colors Available!
    Click HERE for more information!
    Thanks to everyone for your continued support! If you have any questions or would like help placing an order, please don't hesitate to shoot us an email or give us a call!
    [email protected]
    209-968-0077
    Jake
    Veteran Member Four Rings ryanhmusic's Avatar
    Aug 05 2014
    jack stands, a power washer, hand tools, bones of my fallen enemies, etc
    Your link for more info isn't currently working for me
    edit: sorry I had a B7 selected...your site could use a little update on that feature
    I'm living for the day I can park something Italian inside of my house.
    I had one wild summer on match.com. -some jackass
    01100010 01100001 01101110 01100001 01101110 01100001 00001010
    Aug 31 2011
    Lathrop
    Quote Originally Posted by ryanhmusic View Post
    Haha, working as planned! It's designed to not show you products that don't fit your car.
    Aug 05 2014
    Quote Originally Posted by Jake@JHM View Post
    well in that case it works brilliantly except I didn't have my car selected either
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    How many $ is "low cost"?
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Sep 01 2012
    Edmonton
    Quote Originally Posted by blbroo View Post
    "$2,650.00" low cost.
    2018 RS3 Panther Black
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by WAF View Post
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Ecs sell rs5 8 piston kit for about the same price....
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Sep 01 2012
    Edmonton
    um yup, I figured you'd have a good meme. lol
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by hyperunion View Post
    Well, that kit starts at $2900, and gets up to $3100 if you opt for the wave rotors. This kit also runs 17mm larger rotors than even the RS5 kit. I think this kit is actually the better value just for that reason. You're not going to see a whole lot of stopping difference between a 6 piston vs. an 8 piston caliper of the same style - but you will see a bigger difference if the braking force is moved further from the center of the hub.
    Also, when you compare it to, say, the Stoptech St-40 BBK and it's 332mm rotors at $2500... this isn't a bad deal at all.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    Quote Originally Posted by adamazing View Post
    There is a lot more to do with braking performance than just the number of pistons and the size of the rotor. You have to compare apples to apples. Running an RS brake setup or Porsche or Q5 are going to increase your stopping abilities. However, none of them are in the league of a real BBK. The rotor size is not everything...
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    FWIW, ECS offers this same kit, and has for awhile now. 19Z with 380mm rotors, and at essentially the same price- with their in-house brackets and rotors of course; but still, same thing.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    Love JHM! Do you guys have a fitment template that's printable to check fitment? The website says 19" or greater; I'm on 20s but they're really concave.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Great looking BBK! Hope to see more on other B8's soon.
    Aug 31 2011
    Lathrop
    Quote Originally Posted by earhythmic View Post
    We don't have a template yet, but worse case for you is you may need some wheel spacers. How much clearance do you have with the stock brakes?
    Quote Originally Posted by A4 Centaur View Post
    Thanks, me too!
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by poweredbyaudi7 View Post
    Nobody is arguing that, but how does that relate to my comparison between this and the RS kit with ROI involved? Of course there are other elements involved - pad material, unsprung weight, clamping force, heat dissipation, etc.
    But I'm only specifically talking about the difference between this kit for $2600 vs an RS kit for $3000.
    Dec 19 2006
    996TT
    San Antonio, TX
    You're correct, I was referring to you talking about the Stoptech. More for others than yourself. A lot of guys on here think that the larger the rotor, the better the Kit.
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    JHM.... when are yall jumping on the tune bandwagon for the B8/B8.5?
    Sincerely,
    Audizine
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Aug 31 2011
    Lathrop
    Quote Originally Posted by AllroadCorbin View Post
    Sincerely,
    Audizine
    When the time is right
    Jan 15 2014
    Boston, MA
    Yea that's now. k04 tune please.
    Good talk
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Oct 26 2012
    St. Louis, MO
    Good talk
    What a jerk. Get lost rotorboy.
    Jan 15 2014
    Boston, MA
    How's the K04 coming Brian?
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Oct 26 2012
    St. Louis, MO
    Touche, my friend.
    I was just teasing Corbin, would love to see more JHM activity on B8s.
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    By the time JHM comes out with B8 stuff there won't be anything left for me to do except do a full engine build and trans swap. :)
    My 2009 A4 Prem+ Build thread
    Aug 31 2011
    Lathrop
    Our turbo kit will bolt up. you would just need to find tuning.
    Jul 07 2012
    Boston, MA
    Custom tune ~$1000
    APR k04 file $500 :/
    Aug 31 2011
    Lathrop
    Quote Originally Posted by Lambda13 View Post
    Custom tune ~$1000
    Do you already have a k04? Our stage 3 kit for the B7 could be pushed a lot harder on a B8
    https://jhmotorsports.com/shop/catal...0t-p-2588.html
    Aug 05 2014
    would you guys do the tuning?
    Jul 07 2012
    Boston, MA
    I am picking up a k04 soon (deal made). Does that kit fit a B8 though?
    Aug 31 2011
    Lathrop
    Not just yet
    Oh okay. The turbo/manifold would bolt right up.
    Jul 07 2012
    Boston, MA
    Not just yet
    Good to know. If I want moar power down the line I'll keep that kit in mind.
    Oct 26 2012
    St. Louis, MO
    NICE! I want to see this happen.
    Aug 31 2011
    Lathrop
    We also have an affordable FMIC to go with it: https://jhmotorsports.com/shop/catal...0t-p-3555.html
    Oct 26 2012
    St. Louis, MO
    link comes up as "Product Not Found!"
    Aug 31 2011
    Lathrop
    Hmmm what vehicle do you have selected?
    Jan 15 2014
    Boston, MA
    I had no idea JHM made an FMIC for our cars..
    Also, that Turbo set up looks pretty awesome. My interest sir..... you haz it
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Aug 31 2011
    Lathrop
    Yup!! We make several parts for the B8 A4!
    Jan 15 2014
    Boston, MA
    Not sure why but myself and many other B8 morons kinda assumed JHM was not in the B8 game. hell I might go make a thread with links to JHM stuff for the B8
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Aug 31 2011
    Lathrop
    Haha really? We have been selling those parts so maybe the people buying them are the low-key guys lol
    Jan 15 2014
    Boston, MA
    All the cool kids
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
