Results 1 to 40 of 59
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Thumbs up Now Available: JHM B8/B8.5 Porsche (Brembo) 382MM Front Big Brake Kit
    JHMotorsports is pleased to introduce a low cost, 100% Bolt On, Front BBK (Big Brake kit) solution for your B8 A4-S4 A5-S5 that uses the popular Porsche Brembo 6-Piston Caliper, also commonly known as the 19Z!
    INCLUDES:
    2x - JHM 2-piece Lightweight Slotted Front Rotors
    2x - JHM Caliper Brackets with Mounting Hardware
    2x - BRAND NEW OEM Porsche (6-piston Brembo) Calipers
    2x - Stainless DOT Approved Brake Lines
    1x - Set of OE Pads Brake Pads
    1x - OEM Brake Pad Sensor (Driver Side Only)
    1x - Liter Pentosin DOT 4 Synthetic Brake Fluid
    INSTALLATION: This is a COMPLETE 100% bolt on Big Brake Kit for the B8 Chassis. This kit requires ZERO modifications, cuts, grinds, splices, etc. making installation quick and simple. NOTE: The stock Dust Shields will need to be removed for proper clearance
    OEM S4-S5 Rotors vs. JHM Lightweight Rotors (A4-A5 vehicles will yield greater results)
    -Rotor Weight: Stock = 23lbs(each), JHM = 24.1lbs(each) - Only 1lb heavier for a MUCH larger rotor
    -Rotor Cooling Air-gap: Stock = 11.5mm(.450"), JHM = 18.5mm(.728") - LARGER for better cooling
    -Rotor Cooling Center Fin Design: Stock = One Direction Airfoil (one side pumps the air from the inside out and the other side pumps the air from the outside in), JHM = Airfoil (side specific rotors that both pump the air from the inside out) - EQUAL EFFICIENCY for equal cooling
    -Rotor OD: Stock = 345mm(13.6"), JHM = 382mm(15.039") - 1.43" LARGER
    -Rotor Thickness: Stock = 30mm(1.18"), JHM = 34mm (1.33") - 4mm (.15") LARGER
    -Bolt pattern: - SAME (fits like an OEM rotor would)
    Why the Porsche Cayenne caliper?
    With its 6-piston design and MASSIVE brake pads it is a strong performer. Also it bolts right up to your spindles using our JHM CNC'd Caliper Brackets. All you need is the included bolts, brake lines and JHM rotors and you have a 382mm Big Brake Kit.
    Outer ring specs:
    We worked closely with a race brake manufacturer that supplies many NASCAR racers and a couple major brake kit companies. Due to their expertise we chose to have them build us the outer rings to our specs to fit the B8 Chassis. 12 attachment points for durability and strength.
    Center hat specs:
    We CNC machine the Aluminum center hats in house based on their recommended materials and thicknesses for durability. 12 attachment points for durability and strength. We also engrave JHM in them in 3 locations equal from each other, it looks clean and doesn't jump out or look tacky.
    Custom Caliper Colors Available!
    Click HERE for more information!
    Thanks to everyone for your continued support! If you have any questions or would like help placing an order, please don't hesitate to shoot us an email or give us a call!
    [email protected]
    209-968-0077
    Jake
    Jan 24 2014
    United States
    Wow. Great pricing
    Aug 31 2011
    Lathrop
    Quote Originally Posted by LaCross View Post
    Wow. Great pricing
    Jan 24 2014
    United States
    Quote Originally Posted by Jake@JHM View Post
    Np, this is probably the best bang for the buck brake upgrade. Only recommendation i'd make is using different pads, or have the option to (if you dont already.)
    Aug 31 2011
    Lathrop
    It definitely is!! These are still a fairly new caliper, so as soon as performance pads start hitting the market we will make the options available
    I will note though, this kit with these pads stop a B8 Chassis car AMAZINGLY
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    whelp so much for the SQ5 brakes... lol I def would like these, hopefully in the near future.
    Hopefully some carbotech pads become available.
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Veteran Member Three Rings 13allroad's Avatar
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    Will these bolt on to the c7 a6 TDI? I know the TDI is the same size as the 2.0a6 which I believe is the same as the b8 a4?
    If not any upgrades that you offer?
    Current: Quantum Gray Metallic SQ5 / JB4 / Carbon Mirror covers
    Old:
    2014 A6 tdi prestige, HRE FF01 wrapped in Conti, black optic, sport package, LED package, RS7 Pedal Kit, 034 Trans mount, Alu Kreuz, Eurocode sway bars/end links, rear spoiler, Vag Com Mods, piggy back tune.
    2013 allroad tuned and modded.
    Weekend rider - 2015 BMW R Nine t - custom
    Aug 31 2011
    Lathrop
    Quote Originally Posted by theswoleguy View Post
    Yeah, let us know when you are ready!
    Quote Originally Posted by 13allroad View Post
    PM me your VIN so we can take a look!
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    Man how I wish we could get the Red calipers without the "Porsche" written on it :(
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    PM sent
    Old:
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by justr0 View Post
    Im sure you can. It'll just cost more and take longer.
    Definitely like the idea of this upgrade. Those calipers are gorgeous.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    May 13 2011
    2015 BMW F30
    will you guys ever have the option for drilled rotors?
    | Autospeed | JHM | Pure MS
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    How would you know!? You drive a Golf! I keed, I keed! Good looking brakes JHM! Too bad you don't offer anything that makes my car fast enough to need them ;(
    2021 Audi S4, P34 Intake
    Aug 31 2011
    Lathrop
    Quote Originally Posted by S4 00 2.7 View Post
    As of right now, I don't think so.
    I had the pleasure of driving our JHM SC'd B8 S5 with this very BBK kit installed today, that's how!! lolol
    Hey don't you worry about that. Get the brakes now, and when we do release those products you will be ahead of the curve!
    Veteran Member Four Rings Lensch09's Avatar
    Feb 20 2004
    2022 B9 RS5 SB, 21 Rav4 Hybrid, some golf clubs
    Santa Clara, California
    When do we get to do a test fit of one of my wheels? As always, looks great! Thanks again for letting me see them first hand!
    -DL
    2022 RS5 Sportback - Navarra Blue
    Previously:
    2016 Audi S4 Prestige with tons of boltons -Build Thread - http://www.audizine.com/forum/showth...016-S4-Ordered!
    2007 Audi A4 S-line Ti APR GT2871R
    1999 Audi A4 Avant (S4 replica)
    2000 Audi S4 Sedan (Stage III)
    1999.5 Audi A4 1.8TQM Sport (bolt-ons)
    Aug 31 2011
    Lathrop
    Quote Originally Posted by Lensch09 View Post
    -DL
    Haha no problem! As soon as you place the order ;)
    Oct 14 2012
    Empty...for now...
    SE PA
    I'll be keeping my eye on this for if/when low dusting brake pad options become available. I don't like the weak braking of my B8.5, but I love my low-dust Akebono pads.
    SOLD 2015 Daytona Gray S4
    Aug 31 2011
    Lathrop
    Quote Originally Posted by SteveYem View Post
    You could always rock the kit now, while its on sale and then swap pads when they are available!
    Aug 31 2011
    Lathrop
    Thanks for the orders everyone!
    For those of you concerned about fitment, our downloadable template is now ready! Click HERE!
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    The stoptech 380mm rotor disks look like they have less visible disk
    and this kit 382mm makes for a bigger appearance of "more silver" or disk surface area
    is that seen as a major difference? i know the calipurs are not the same, so that can play into that, including the pad shape
    anyone wanna take a stab at rotor to pad surface area comparisons?
    2018 TTRS
    Junior Member Two Rings windowguy's Avatar
    Jan 08 2015
    I was looking at the ECS Tuning RS5 stage 3 big brake kit. Anyone have any thoughts on if that would be better than this kit. I have a 2012 S4 tha is for street use. Yes i know that both kits are over kill for the street. I am planning on going stage 2 in the near future.
    Aug 31 2011
    Lathrop
    Thanks for the orders everyone!!!
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Quote Originally Posted by windowguy View Post
    I'm wondering, why is ECS's stage 4 380mm RS5 kit cheaper than stage 3 365mm kit
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    No pads are included with Stg4.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Jan 08 2015
    I bought and installed the ECS Tuning stage 3 brake kit (front and back - back was pads and rotors) and I am disappointed in the brake pads. I had brake fade while doing my 10 stops for the bedding in process. Otherwise everything else is very good. Pedal height drops a bit so heel and toe is a little harder but not impossible.
    Sent from my SM-N920W8 using Tapatalk
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    Has anyone installed this kit and offered any feedback?
    Dec 03 2008
    2018 SQ5
    Brakes shmakes. Let's see some software!
    Aug 31 2011
    Lathrop
    Quote Originally Posted by S-Fore View Post
    We have sold quite a few of these kits, so there should be some somewhere! We also have a special deal for only ONE set, so if anyone is interested let me know.
    Ptsh you couldn't handle it ;)
    Veteran Member Three Rings abamfo's Avatar
    May 12 2016
    Melbourne, Australia
    Do you guys sell this kit without rotors?? Also given how much larger the brake is than stock, how does the OEM master cylinder and brake booster step up to the plate?
    Feb 20 2004
    Sounds like we will be test fitting one of my wheels this weekend. Anyone wanna put a side bet on 19 X 9.5 ET40 AG wheels clearing these beasts?
    My wallet almost hopes they won't. We'll see!
    -DL
    Previously:
    Aug 31 2011
    Lathrop
    -DL
    It's going to be sexy
    Feb 20 2004
    I don't care for that fruity Carolina blue. Gonna have to be black powder with the S4 logo. Ahhhh, the decisions/bets made while drinking beer.
    You'd think after 31 years I'd have figured that out.
    -DL
    Previously:
    Aug 31 2011
    Lathrop
    -DL
    Ahh going for the stealth look?
    Feb 20 2004
    Not sure that my car is really sneaking up on anyone... But yeah, something like that. More OEM+ than anything.
    -DL
    Previously:
    Veteran Member Three Rings Teamnct4's Avatar
    Aug 06 2010
    2015 S4 & 2022 S4
    NY & SC
    Do you guys offer a drilled rotor option? This is some great pricing.
    2015 S4 Premium Plus, Mythos Black, Black/Magma Red Interior, Black optics package, Aluminum Mirror Caps, Carbon Atlas Inlays, Airlift 3P, Airlift performance front and rear shocks, AWE touring with 102MM Tips, E-Codes, 20X9 HRE FF01.
    2020 RS3
    Established Member Two Rings ofspecialk's Avatar
    Nov 06 2016
    Silly question here, but what if I already have the calipers collecting dust in my garage? Do you have a kit that has no calipers or can i but the parts separately for your kit?
    Btw how does the stock S4 brake booster deal with these or does it need to be upgraded?
    Feb 24 2013
    CA
    I already have some 19z calipers so i was wondering, do you guys just sell the caliper brackets seperately?
    Nov 06 2016
    Quote Originally Posted by Slick_B8 View Post
    same thing i just asked lol
    Feb 24 2013
    CA
    Quote Originally Posted by ofspecialk View Post
    Lmao fml i skimmed thru your post haha
    Nov 06 2016
    its all good. im torn between the RS7 calipers i found cheap, the 19z, and the Q5. Q5 seems to be the best bang for your buck.
    But then you had to go and mention that you can use a 6/7 calipers and rotors..... and i cant find anything on that. but its a way more affordable option than any of the other options.
