Clean and rust free 2001.5 S4 with about 300 hp. I have done everything that is preventative maintenance to this vehicle, and I have a Carfax upon request.
Lets get to all the goodies and maintenance.
Maintenance
K03's Rebuilt
Timing belt replaced
Timing tensioner gasket replaced
Water pump replaced
Thermostat replaced
Valve cover gasket replaced
Coolant temp sensor
Oil pressure sensor
Ceramic Brakes installed
Yokohama 580 tires all around, warrantied, free rotations, flat repair and replacements.
Aux water pump replaced
Spider hose with custom 200psi hose replaced
New NGK Spark plugs
New Oem O2 sensors
New Continental serpentine belt
New Battery as of 2015 warrantied
New hose clamps(boost leak prevention)
Coolant flush with Heater core flush
Power steering flush.
New 710N diver valves
Upgrades
Engine mounts upgraded
Transmission mounts upgraded
Drilled slotted rotors
JHM short shift kit
Silicon hose kit
SSAC Twin 2 Exhaust with down pipes
Unitronic Stage 2 tune 20lb boost
Boost Gauge
Code matching painted Y pipe
Probably more that I can't think of.
Call or text me for more information, 4027069935.
Car is no longer being driven and located in omaha nebraska.
