Results 1 to 13 of 13
    May 31 2011
    moore
    Need to replace?
    So i hit the curb and this is a result. Do I need to get new tires or I should be fine?
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    That sucks man, i can relate. Imo you should be fine without changing the tire.
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    I did exactly the same thing with my A5, and it took a chunk just like that out of one of my tires. I freaked out and figured I ruined the tire, but when I took it to local shop I trusted, they said it was OK. I'd keep an eye on it just to be sure it doesn't bubble especially when it gets hot out.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Your fine, super glue it back, and if your tires are not directional you can have them flip that to the inside.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Apr 05 2016
    Portland, OR
    It does not look very deep so I think you will be fine.
    I would get the rim repaired though as it is a little unsightly
    May 31 2011
    moore
    Thanks for the insight everyone!
    Veteran Member Four Rings MVR 155's Avatar
    Apr 04 2013
    2018 Audi S6, 2015 GMC Yukon Denali and 2002 Corvette Z06
    Bartlett, IL
    As the others have stated that is a non issue, you basically tore a bit of the extra rubber designed to help protect the edge of the wheel lip. either glue down or cut that piece off and then get some matte black paint and touch up your wheel. Unless you're specifically looking for it, nobody will ever notice.
    2018 S6 Prestige, Glacier White/Black, S-Sport, Driver Assistance, Black optic, Carbon inlays, Cold weather, Vorsteiner VFF 103's in carbon graphite.
    2002 Corvette Z06
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Where did you buy the tires? Tire Rack will send you a new one if you purchased through them.
    Mar 01 2016
    Gone: 2007 Acura TL Type S, 2004 Acura TL, 2005 VW Passat 1.8T
    NH
    I did the same thing to one of my tires and at first freaked out a bit but then realized it wasn't losing air and its been fine since.
    2013 S4 DSG | VX3 LED Fogs | LED interior conversion | LED reverse lights and plate lights | CR-15 Strut Tower Brace | 35% Window Tint |
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Your good keep on getting it. Unless you see steel then your fine. Rock it.
    Veteran Member Three Rings Senseless's Avatar
    Aug 11 2015
    Phila vicinity/ PA/ US
    I did the same thing a month ago and it's been ok. I thought I had damaged the entire right side of the car, so I was relieved when I got out and saw it was just the tire and wheel, like yours. Can the wheel be refinished?
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    and keep in mind if for any reason you decide to replace the tire - you'll need at least the opposite side axle tire if not all four.....
    AWD has demands that require the tires remain in close proximity to each other in rotational diameter - to keep the diffs from binding up and tearing themselves apart - so you can never replace just one tire......
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Veteran Member Three Rings MerkurRS's Avatar
    Oct 04 2012
    Four Passat W8's, 2003 allroad 2.7t , Ford Excursion Ltd V10, 1989 Merkur Scorpio, 1987 Merkur XR4Ti
    Berthoud, CO
    You're fine. You scraped the part that is intended to help protect the wheel lip. I did the same thing (gasp) as well. Had the shop double check it- they confirmed it's ok.
    2012 Audi S4 Prestige Glacier White, Alcantara Leather, Titanium/ Black Optics Pkg, Auto/ Driver Assist/ Drive Select/ B&O/ Carbon Inlays, UltraCharger, APR Carbon Intake, Flat-bottom Wheel, 3G+Google Map conversion, Passport 9500ix red/carbon limited edition, Michelin A/S 3's, Armytrix/ Custom Exhaust, Spulen Diff Mount, 034 Trans. Insert, Eurocode Alu-Kreuz, ACNA Member
