Results 1 to 12 of 12
    Feb 15 2016
    Cambridge,Ontario
    anone else ever get freaked out putting spark plug in ?
    especially when its a new to you car when you are not sure what to expect.
    The spark plugs in my car I was able to loosen with literally one hand on the top of my wrench .. so im thinking uh oh ...
    went to put the new ones in with the torque wrench... tighter.. tighter... tighter.... then less tight ....
    I know its coming as the crush washer decides to collapse an then it tightens up . But still to this day after 35 years of wrenching cars it still makes my heart stop when I feel it as I think I have stripped out the spark plug hole. BTW washer starts to crush at about 18-20 lbs torque ( I use a beam torque wrench as I just don't trust the clickers for that sort of stuff. )
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Four Rings vortexjunkie's Avatar
    Sep 12 2009
    Manteca/Lathrop
    I just did this exact thing last night with my new to me car. I have also started vacuuming out the holes before pulling the plugs because of crap found in there from other owners. The possibilities of a already stripped hole are my biggest fears.
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    I always get nervous, but I pull them when the engine is dead cold. Either that or have someone do it so if it breaks, it's their problem and not mine.
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Quote Originally Posted by miA4 View Post
    Best way to do it because the metal is relaxed and 'loosen'. This way you know when not to over/under-torque. Misfires are easily prevented with this simple step.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Feb 15 2016
    Cambridge,Ontario
    believe me a tech would get it snug if he stripped it and get it out the door in most cases. even if they strip it you would have a tough time getting them to take ownership , you will hear it was already like that .
    1976 Yamaha XS 360
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    Always use a torque wrench. Do it yourself on cold engine and realize things change after removing a plug because if it's crush washer.
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Yup. Invest in a torque wrench guys. One very important tool
    2008 A4 S-line 2.0T
    JHM Stage 2
    Nov 15 2011
    Montreal | I sell in USD
    I dont even remember the torque specs lol Its always hand tight plus a bit. Worst is I have three different torque wrenches.
    Is it 21lbs?
    *****I sell in USD*****
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    I don't use it either on my plugs, and I have 2 also lol
    2008 A4 S-line 2.0T
    JHM Stage 2
    Veteran Member Three Rings teg2audi's Avatar
    Apr 23 2008
    Portland, OR
    22 lbs
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    Guys: Don't be too concerned about torquing spark plugs in a warm or hot engine. The difference in the yield strength of aluminum and its alloys at ambient temperature relative to 212 degrees F is very small - probably about 5%, and few folks are working on engines at 212F . The factor of safety for plug torque is probably in the neighborhood of 60%. There is no reason to over tighten spark plugs. Just snug them to the specified torque hot or cold and you'll be fine. In my motorcycle racing days we used to do plug checks for carb jetting by killing the engine after 5 miles at pretty much WOT using the kill switch. We'd then pull the plugs and believe me they were hot as hell, check them, and put them back in, always torquing to minimum. Never stripped one, never had one loosen. Same thing with all the planes (air cooled engines, aluminum heads) i've owned but if you are not comfortable with this, that's fine too.
    Mar 19 2014
    Unless you want to gamble with fissures in your heads. Use a torque wrench whenever you can wherever you can.
