Page 1 of 3 123 LastLast
Results 1 to 40 of 93
    Apr 05 2016
    What ECU Tune to go with?
    I did my research, searched the forum and Im still stuck on deciding which one to go with.
    I recently purchased a 2012 S4 DSG (love it) but Im looking to get the Stage 1 ECU tune. After looking through the forums I have come to the conclusion to pick between either GIAC Stage 1, or REVO Stage 1. Just wanted your guys opinion on which one to go with.
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    GIAC
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    GIAC
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Senior Member Two Rings Shaun Perry's Avatar
    Jan 02 2013
    San Ramon, CA
    Considering GIAC as well. I'm assuming off their site the "Xplus" tune is stage 1? Says it is compatible with a stock car but can benefit by an intake and exhaust.
    And their transmission tune. Is anyone running stage 1/Xplus and the "T2" tune together or is there no real benefit until adding the pulley and going stage 2(X2).
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    I'd say GIAC over revo if that's the only two you're set on. I still remember how bad revo sucked for the B5 market years ago so it's hard to get it outta my head.
    Any reason you're not considering EPL?
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    You didn't do enough research if REVO and GIAC are your only options...
    IMO, EPL is at the top of the list, as well as 034, who should have an official software release next month I'm hoping. If I were to purchase software in the next few weeks, it would be between those two companies.
    Nothing against GIAC, they do hold the 1/4 records, but only because it just happens to be GIAC users thinking outside the box. I do believe 034 will come out stronger than GIAC...
    2021 Audi S4, P34 Intake
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    At stage 1 levels of power, you really can't go wrong with REVO or GIAC.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Apr 04 2015
    United States
    I have AWE stage 2 which is GIAC tuning, with the GIAC DSG tune. its smooth when you want it to be, and violent when you step into it. Overall, I am very pleased!
    That said, I'm certain that the REVO or EPL etc will give you the same results.
    From what I have read, I would steer clear of the APR DSG tune, or at least until they work out the bugs.
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    EPL
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Veteran Member Three Rings BDP's Avatar
    Feb 07 2015
    Ohio
    I'm in the same boat, I literally have $$ burning a hole in my pocket. Since this is the seventh VAG car I've had over the years, I've actually had pretty much all of the major tuners on my vehicles, APR, GIAC and REVO. I have no allegiance to any of them and they all worked well for me. I slightly lean towards APR because they gave me a free tune back in the day when they were releasing their "V-tune" software for the 1.8T...years ago, I helped beta test it. My only problem is APR is literally the most expensive and the shop that would do the install is the most expensive in getting the work done (Dubwerx, Cincinnati). I can go to the local GIAC shop and have resonated downpipes & Stg 2 installed for less then just getting a Stg 2 tune down there.
    The jury is still out with me on EPL, I've been reading the forums and the threads on them. However, there just isn't enough of a user base or results that make me feel comfortable jumping that direction. On top of that I don't know much about the company...will they support the platform for years to come. Plus I'd have to do the pulley install myself.
    2018 Glacier White RS3 - Unitronic Stage 2 (E85) ECU, Stage 2 TCU
    2014 Estoril Blue S4 (DSG) - Sold (11.2@121mph 93 octane)
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Quote Originally Posted by DannyDeez View Post
    Or Unitronic
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Veteran Member Three Rings ALAN12186's Avatar
    Mar 30 2016
    Brick, NJ
    APR!
    13 S4/6mt/SDiff/MMI/B&O/Black Ops/APR Stg2+ Ultra,SC & 187MM Crank Pulley,TB & CPS V2/APR Intake/Milltek Res GT100/TA HF Cats/FF103 19x9.5/ Vorsteiner Front Lip/E Codes/ECS Diffuser/P3-Vidi Track Pack/Bilstein B12 & H&R OE Springs/EBC Red Pads & Slotted Rotors & SS Lines F&R/Brembo Calipers/CR15/APR 7MM F&R/034 Sway/Moog Links/ECS Drivetrain Mounts/Eurocode Krez/ECS Clutch Line/034 Trans, Motor & Sub Mount/SB STG 3 Clutch/USP Slave/Enlaes Spoiler/ECS SS/Autotech HPFP/Jokerz Blower/Killer Chill
    Senior Member Two Rings dyl0n's Avatar
    Dec 14 2014
    New Orleans, LA
    https://youtu.be/xWxE1neO774
    My APR Stage 2 shifts funky.
    Senior Member Three Rings sh!tmagnet's Avatar
    Apr 22 2014
    Kelowna
    Daz Dillenger (RIP) did my stg 2 tune; look into Vagwerks. They're in the NY area. Very happy with the tune over the last 15k miles. Alot better pricing too than the major tuners.
    Stage 2 Banner Advertiser Four Rings
    Sep 06 2007
    Quote Originally Posted by BDP View Post
    Of course I beg to differ the jury being still out . results are proven and solid. Track times continue to get faster and faster (most recently 11.8 @116 on pump fuel stage 2 single pulley set up). Development on the platform started in late 2012 our own shop car which we owned and developed on for over a year before releasing software to the public.
    Without getting into specifics, we're selling tunes as fast as we are able to provide flashing cables. Our customer base is quite broad at this point.
    We have been in business for 10+ years. Little known fact is my business is a direct result in lack of support from a company that is still active on this forum. We were the first to bring home flashing to this community and we actively update calibrations (often weekly).
    The support for this platform has only BEGUN and I dont see any reason why it will tapper off any time soon (we still support 1992-1995 s4's and s6's for reference). As for installing the pulley yourself, I can recommend several shops in OH and honestly most general repair shops that do even a little performance work will have no issue installing the pulley for you as well.
    We'd gladly call you if you would like to discuss tuning.
    Veteran Member Three Rings shoe3k's Avatar
    May 18 2015
    weedwhacker
    No where
    Quote Originally Posted by dyl0n View Post
    I have seen this issue with GIAC, APR, and even stock tunes. I believe it is something with the ECU and TCU not being in sync. It's funny because I get this with the stock tune when shifting at WOT after 5000 RPM. If I manually shift a few hundred rpm before 5000 RPM it is always lighting quick with very crisp shifts. Otherwise, in S or manual mode I get this annoying hesitation after a shift when crossing the 5k barrier. I can replicate this all the time where it will shift, pause, drop 100 RPM, and pick up accelerating again.
    Previous: |'18 Golf R | '17 S6 | '15 S4 | '15 STI | '12 GLI Autobahn | '08 Passat | '04 R32 | '05 GTI 1.8t |
    Stage 3 Forum Advertiser Four Rings ModdedEuros's Avatar
    Aug 23 2014
    Philadelphia, PA
    Would take a look at Unitronic and UniConnect+. Can now just flash your ECU yourself right at home. No more need to go to shops for labor fees. You can upgrade and downgrade in minutes on your own
    Have more info on tunes onsite
    https://www.moddedeuros.com/audi/s4/b8-10-13/tuning
    Modded Euros
    Your Source for Audi & VW Performance Parts
    www.ModdedEuros.com
    Aug 09 2015
    Sarasota, FL
    More and more times will come out for EPL, you have to remember that the EPL group buy started when the majority of tracks were closed. I think they recently took the stage 2 pump fuel record (albeit by a few hundredths of a second, but that's to be expected for our platform). The progression is good coming from the days when Saxon had an EPL tune, and I too had one previously; I was running .2 @ 2mph slower than a comparable APR stage 1 tuned car with AZ member FLYINLEGGS, but that was last Sept. and there has been revisions since then.
    Tony@EPL is very dedicated to making sure the tune progresses, which is admirable and something to consider when purchasing as well!
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    go with REVO if you want to be the slowest
    Jan 26 2015
    Clemmons
    EPL, Cannot beat being able to flash at home and then flash back if needed. Also updates wont require going to some shop for flash updates.
    Feb 07 2015
    Ohio
    Quote Originally Posted by Loe View Post
    Why aren't you using them? Don't they have a dual pulley tune that would allow you to maybe ditch the chipwerks piggyback?
    Aug 09 2015
    Sarasota, FL
    They do, but my current set-up works fine the way it is and how it integrates nicely with the GIAC stage II file that I don't feel the need to spend another $1000 or so to obtain a dedicated file at the moment. If someone beats my current record, then I would possible consider switching
    Feb 07 2015
    Ohio
    Ha! understood. There is no chance in me beating the record for sure. Even though there is literally 3 tracks within an hour from my house, with one being 20 minutes away. We are sitting about 1k above sea level here.
    Jul 10 2015
    Franklin,TN
    I simply cant say enough great things about EPL. Top notch service and support not to mention awesome results.
    2016 S6 Prestige
    2012 S4 Prestige, Sports Diff, Nappa Leather, ECS Kohlefaser Luft-Technik Intake System, EPL goodies
    03 350Z Crawford 265 Cams, Plenum, Headers, Cats, Big Bore TB, Fujitsubo Ti Exhaust, TS ECU, JWT Intake, Clutch, Flywheel
    Oct 27 2010
    Michigan
    How far are you from Thompson dragway? Primetime has put up some quick times there
    Aug 09 2015
    Sarasota, FL
    You may be able to or at least run near it with a similar set-up to mine in 1K D/A's...
    not to derail the thread, when I reviewed my logs in my most recent run in 1200ft D/A's where I ran [email protected] (I guess I'm technically the unofficial place holder for the next 7 or 8 spots as records, but I haven't shared all of my 11.2-11.3 second times I've had...lol), I feel an 11.2x@121-122mph could have been doable with proper cooling on that run.
    some food for thought
    Veteran Member Three Rings Batman0424's Avatar
    Dec 11 2015
    2020 SQ5, 2020 Audi Q3, and 2010 Mini Cooper S
    Hopewell, NJ
    Quote Originally Posted by VandyZ View Post
    Agreed. I was not sure I wanted to tune at all until I looked into EPL and spoke with Tony (and this was back in Feb of this year). After going Stage I at home, I quickly decided that I want to go Stage II and now I'm adding the dual pulley and giving my car to Tony to dyno tune. My only problem is that I have to wait another 2 weeks before my car goes to the shop.
    2020 Audi SQ5
    Nov 10 2014
    Apex, NC
    your research led you to revo as one of your top choices? you sure you weren't in the 1.8T forum?
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    May 18 2015
    weedwhacker
    No where
    Quote Originally Posted by Batman0424 View Post
    Sorry. Had to do this.
    Aug 21 2014
    Boston
    I, for one, am glad I went EPL. Flash from home, great feel and power, 1/4 mile results, and my experience with Tony has been nothing short of awesome. Now if I could find the time to get this damned pulley installed!
    2015 Ibis White S4 DSG
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Quote Originally Posted by rwtzero View Post
    Source?
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Apr 27 2011
    MD
    Quote Originally Posted by joediesel View Post
    x2
    all good so far
    IG: @s4dad
    Oct 17 2014
    NorCal
    While I have a GIAC stage 2 (came with car) if I was untuned EPL was my choice.
    2019 RS3
    2014 S4 P+
    Jul 10 2015
    Franklin,TN
    For those of you EPL customers still waiting to get your pulley installed and flashed to stage II....all I can say is hurry up and wake the beast!
    2016 S6 Prestige
    Nov 16 2015
    DFW
    Note: I run EPL and to me its the best out there based on flexibility (flash at home, E85, dual pulley, etc etc)
    I figured he asked between Revo and GIAC, so that was a no brainer.
    Feb 07 2015
    Ohio
    Quote Originally Posted by mrmomo313 View Post
    Thompson is about 4hr's north of where I'm at. I can run down to Edgewater in Cincinnati to defeat some of the elevation. They are about 800ft above sea level down there but that is probably the furthest track for me to travel to at just outside an hour.
    Veteran Member Three Rings Zaxon55's Avatar
    Mar 13 2014
    Centennial, CO
    I was in the same boat, finally decided that they are all within a tight range in terms of daily driver performance for my needs and scheduled with APR Stage 2 for ECU and TCU.
    2013 B8.5 - Moonlight Blue Metallic
    - VMR V710 19x9.5 -APR Dual Pulley -AWE Coldfront System -Eurocode Alu Kreuz -Front/Rear Sways and Endlinks -ST Coilovers -SPC Control Arms -034 Transmission Mount and Diff Mount -Roc Euro Intake -Porsche BBK with ECS Drilled/Slotted Rotors, SS Lines, Pads -CR-15 Upper Strut Tower Brace -AWE Touring Exhaust (102mm and stock downpipes) -Deval Diffuser, ECS front and rear spoilers.
    Apr 27 2011
    MD
    lol thats me, should have the pulley kit by Friday, very excited.
    Nice improvement over stage 1?
    IG: @s4dad
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Just dropped Revo like its hot today.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Apr 27 2011
    MD
    Quote Originally Posted by fitzydude View Post
    Well done sir
    IG: @s4dad
