Results 1 to 25 of 25
Hybrid View
    Established Member Two Rings ecjr173's Avatar
    Aug 08 2008
    05 A4 1.8T S-Line
    Loud whining at start up. Video included.
    Hey guys, so i keep getting this loud whining sound when i start up my car. It last for a couple of minutes then goes away for a few seconds and comes back for about 7-8 seconds. Then it goes away. I won't hear it again until i restart it the next day or after its been off for a few hours. You can hear it more the second time the whining starts around the 2:10 mark of the video. Any help on what it can be would be appreciated. Thanks
    05 A4 1.8T S-Line
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Secondary air pump. It runs for about 90 seconds during a cold start and shuts off. Then 45 seconds later it cuts back on for a short interval. The second time it runs is when the ECM performs a rationality test to make sure it is working properly.
    Are you getting any DTC's such as a P0411?
    Aug 08 2008
    05 A4 1.8T S-Line
    Im not getting any codes or CEL. I have only scanned it with my buddies OBD II scanner and cleared some misfire codes. Other than that nothing.
    05 A4 1.8T S-Line
    Active Member Two Rings WOT's Avatar
    Apr 18 2016
    A few!!
    Elizabeth city, North Carolina
    Delete it from your entire system and code it out.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Dec 28 2006
    Western Maryland
    You definately need to replace the SAI pump. You also need to check your combi valve on the back of the head. During the SAI cycle the combi valve opens and the SAI pump blows additional air into the exhaust stream. Once the cycle is complete the pump shuts off and the combi valve closes.
    If the combi valve is defective and doesn't close completely what happens is that moisture from the exhaust will collect in the SAI hoses and eventually it gets into the SAI pump. This rusts the pump out from the inside and it starts howling.
    You could just have a defective pump. But I would guess that probably half the time when the pump goes bad you will find water in it from a stuck combi valve.
    Senior Member Three Rings ImAudiHeree's Avatar
    Jun 30 2014
    Mercedes Metris
    Sacramento, CA
    Also check for the secondary air hose i had the lower one that connects to air pump disconnect and it made some pretty beautiful sounds like that one did.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by ImAudiHeree View Post
    I don't want this response to get lost in the thread. Whereas I have been pointing the finger at the pump it could be as simple as a loose hose.
    Although I would expect a loose hose would cause a DTC for an incorrect flow.
    Aug 08 2008
    05 A4 1.8T S-Line
    How difficult is it to replace the SAI pump and combi valve. Is there a DIY for these.
    05 A4 1.8T S-Line
    Jan 03 2008
    Richmond
    This is the DIY to remove a lot of the stuff. Install is the reverse of removal. It's annoying work because of the confined spaces. The Combi bolts are allen head but it's too tight to get a ratchet back there. I broke one of those cheap ratcheting offset bit drivers doing the removal because the bolts are in there really tight. Getting the valve off of the bend below it isn't fun either because it's another one without enough space to get a large wrench onto.
    Apr 07 2011
    Quote Originally Posted by userbob0001 View Post
    Just put an 8mm box wrench on the Allen wrench and use the box wrench for leverage.
    Senior Member Two Rings OldmanRacer's Avatar
    Jul 21 2013
    '87 Supra, Murano
    How crucial is the SAI pump for safe operation? Mine going bad too and I read somewhere I think that its not required and that most cars don't have such a system?
    Sent from my HTC One_M8 using Tapatalk
    Aug 27 2013
    Philly
    Quote Originally Posted by OldmanRacer View Post
    Its not anything for safe operation. Plenty of people delete them, but its checked off as a required emissions requirement for our vehicles, so those of us in the USA need the system in place to properly pass inspections. All its job is, is to pump clean air into the exhaust on startup (fuel mixture is richer, thus exhaust is dirtier) so that the overall exhaust isn't as toxic.
    Jul 21 2013
    '87 Supra, Murano
    Quote Originally Posted by SJorge3442 View Post
    To remove is simply just unplugging and removing the pump?? Would it throw a CEL?
    Apr 18 2016
    A few!!
    Yes it will so, code it out and get a block plate for where the combi valve goes.
    Oct 02 2006
    Wadsworth,OH
    ^^ You'd also want to get a block off plate for the combi valve.
    Jason
    Dec 28 2006
    Western Maryland
    Yes she will get a code P0411 for an incorrect flow. You will probably also get a code for the pump itself.
    Apr 18 2016
    A few!!
    Quote Originally Posted by ecjr173 View Post
    Sounds like a leak of some sort. Are you loosing boost? Is the car driving weird?
    Aug 08 2008
    05 A4 1.8T S-Line
    Quote Originally Posted by WOT View Post
    Nope. Runs really good actually!!
    05 A4 1.8T S-Line
    Apr 18 2016
    A few!!
    Check for boost leaks, do a boost leak test
    Dec 28 2006
    Western Maryland
    That noise isn't coming from a boost leak. It is definately related to the SAI system. Either a defective SAI pump or an open line between the pump and and combi valve.
    Apr 18 2016
    A few!!
    Well that's not hard to check...
    Jan 03 2008
    Richmond
    Yeah, the way it all stops right around 90s is pretty solid proof
    Aug 08 2008
    05 A4 1.8T S-Line
    So quick question. Where's a good place to get a pump. Besides the dealer.
    05 A4 1.8T S-Line
    Feb 27 2011
    Winnipeg
    auto wrecker from a 2.slow mk4/beetle, they re under the engine cover in the engine bay up decently high so they are easy to get and don't have the moisture problems that plague the b5/6/passat b5s. Plus it will be from a vw, the u pull here charges $15 for one.
    Dec 28 2006
    Western Maryland
    Check in the classifieds. There are several part outs going on. You can probably get one there for a reasonable price.
