Results 1 to 17 of 17
    Senior Member Two Rings Demringstho864's Avatar
    Sep 26 2015
    Syracuse NY
    Stiffen things up
    OK well with 102k on my car things are starting to feel sloppy. So I plan on changing out my motor mounts with the 034 street density, the transmission mount, and the billet inserts. I have read lots of reviews on the billet inserts. And they look promising. But I can't find a review on the transmission mount for the life on me. Can I get some input on it. I'm ok with it being a little rougher. I enjoy spirted driving. But I want some honest input. I'm also looking at doing brakes all the way around.
    2009 A4 2.0T Quattro Premium Plus
    Static dropped on 20s, lots of bolt ons, and some appearance stuff
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    I cannot overstate how much of a difference the drivetrain inserts made in my 6MT. Completely transformed the car.
    Are you 6MT or 6AT? The street density mount is awesome in @lambda13 's 6AT, but @blbroo hated it in his 6MT. @allroadcorbin is running the motor mounts and seems OK with them. Also, Eurocode makes identical inserts which are cheaper. That's what I have.
    Sent from the Pedal Responce boardroom
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Quote Originally Posted by Project Quattro View Post
    No, he has a strong dislike of those motor mounts.
    Sent from my SM-G900V using Tapatalk
    My 2009 A4 Prem+ Build thread
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Street density will make you hate your car. The insert kits are a must, though. ECS has a set too.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    I hate the 034 50 durometer engine mounts. The NVH is terrible. But I'm an automatic so the car is always in gear while idling... On a 6MT that's not the case in traffic. Yea it stiffened my drivetrain up but if I could do over id buy just new OEM ones
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Senior Member Two Rings sidkneeeeee's Avatar
    Jul 09 2013
    Fairfield, CA
    Would you say is it worth is to install all three or just some of the inserts like only 1 and 2?
    1)Transmission Mount Insert, 2) Rear Differential Mount Insert, 3) Front Bushing Differential Mount
    2010 A4 2.0T P+ 6 Speed CPO / ECS Interior + License led lights / RS4 Grill + Honeycomb Fog cover / Sline Rims 255-35-19 Et43 / ECS Spacer 10mmF:12.5mmB / ECS Inlet hose + Dry Filter / B12 KIT (Bilsteins Shock / Eibach Springs) / 10mm+12mm spacers / Wrapped interior + Window trim + Jcodes / ECS Shortshifter / LED 3200K Yellow Fog / Coilpack, NGK plugs / GFB+ DV / Revo Stage2 / Eurocode HFC / Hotchkis F:R Sway Bars / ECS Transmission Mount Inserts/ Future Mods: Podi Boost Gauge ; 3.0 TDI IC
    Mar 24 2014
    Quote Originally Posted by sidkneeeeee View Post
    Do all of them. Trans mount is a must, it makes a massive difference, and the diff ones are a noticeable improvement too.
    Sep 26 2015
    Syracuse NY
    I'm 6spd tiptronic.
    Sent from my SCH-S968C using Audizine mobile app
    Mar 24 2014
    Quote Originally Posted by Demringstho864 View Post
    I'm 6spd tiptronic.
    In that case the street density trans mount is pretty awesome. Big improvement in Lambda's car.
    Sep 26 2015
    Syracuse NY
    That's good to hear. I don't understand why you don't like the motor mounts though. What is NVH ??
    Jul 07 2012
    Boston, MA
    Vibrations and cabin noise pretty much. It makes the whole car shake at idle. I've been in Corbin's car and it is noticeable.
    Veteran Member Three Rings Jacon's Avatar
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    What is NVH ??
    Noise, Vibration, Harshness
    My current rides...
    Audi
    Jetta
    Sep 26 2015
    Syracuse NY
    Other than the nvh. Does the car feel more solid. Sportier I guess you could say
    Veteran Member Four Rings Poodini's Avatar
    Oct 26 2015
    2016 Subaru Outback 2.5 Limited
    Fremont, NorCal
    You may want to start with 034's Drivetrain mount insert package. You'll definitely notice a marked improvement with minimal NVH. I currently have this kit in my '10 and it definitely made the car feel more stable. Better linear acceleration and just feels a little more connected with the road.
    My understanding in regards to the engine mounts is the 034 solid rubber design, though improves stability, def amps up the NVH. The OEMs were designed with those gaps/fluid filled to combat NVH.
    It all depends on what you're after TBH. If you're planning to track the car quite a bit, I'd def reconsider. If it's your DD and you have passengers on the regular, I'd stick w OEM motor mounts.
    Just my 2 cents
    Sep 26 2015
    Syracuse NY
    Its not a daily anymore. Just somthing fun to drive though the twisties. I might even set up for autocross
    Sent from my Audizine mobile app
    Sep 26 2015
    Syracuse NY
    i ordered the street density trans mount and the billet inserts. im going to install the trans mount and insert first drive it around for a few hundred miles, then do the rear diff mount/insert. i want to see for my self the difference it will make. im holding off on the engine mounts for now do to the reviews i have been reading
    Feb 15 2014
    California
    I have the full setup on my car. It sucks at idle but great everywhere else, ive gotten over it since i dont idle or get stuck in stop and go traffic. I'm 6mt, I've been thinking about removing the trans insert and seeing if it will reduce nvh at idle.
