Results 1 to 10 of 10
    Oct 30 2011
    Urbana, IL
    Comments on Differences between B9 vs B8
    I noticed that the B9 has a smaller gas tank than the B8. Has this had an serious effect on having to fill up more often or does the improved efficiency of the B9 resolve the problem. Also has anyone disliked the fact that there are no front fog lights with the B9?
    2018 A4 Prestige Trim
    Apr 13 2016
    Utah
    https://www.flickr.com/photos/136788.../shares/9g1R7i
    Fogs must be something they are going to offer, this is right off the Audi website
    Veteran Member Three Rings car's Avatar
    Feb 03 2009
    16 S6 93 SLC 91 GTI
    Harrisburg, PA
    Quote Originally Posted by fleeb View Post
    Those are the radar sensors for the adaptive cruise control.
    Established Member Two Rings cameraz's Avatar
    Jul 15 2008
    Massachusetts
    There are switches in the B9 for both front and rear fog lights. I believe the front fogs are built into the headlight cluster (a la original B5).
    Established Member Two Rings Mitchfin's Avatar
    Apr 01 2016
    Utah
    Quote Originally Posted by Prof View Post
    They aren't dubbed fog lights anymore but there are inclement weather lights and rear fogs, and they are all LED (4 LEDS below the beam), fronts are also used for cornering and this is the first car where you can actually tell what the function is; they are very bright and make a huge difference.
    Apr 13 2016
    Utah
    Quote Originally Posted by car View Post
    Oh good to know, thanks for the correction!
    Active Member Four Rings AUDIMAN33's Avatar
    Jan 11 2014
    Quote Originally Posted by cameraz View Post
    I hate that, I really like the independent ones that are built into the bumpers.
    Oct 30 2011
    Urbana, IL
    I also noted some discrepancies from the official AUDI press release on the A4 B9. In which it was stated that, "A good example is aerodynamics: The A4 Sedan has the best drag coefficient in its class at 0.23." However in the AUDI USA site it has the drag coefficient as 0.27 the same as the A4 B8.
    I really do not understand why they reduced the size of the gas tank as compared to the B8. The A4 B9 is a bit larger than the A4 B8 but the new model has a smaller gas tank. This is not good design.
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    That's not a discrepancy. The 0.23 is for the A4 Ultra (not sold in the US). The Ultra model has additional tweaks for higher fuel efficiency. They are just touting the best numbers, but the non Ultra models have a higher drag coefficient.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Senior Member Two Rings dbuxton13's Avatar
    Apr 20 2016
    Germany
    Those are still really low drag coefficients. Lexus is touting its newest F model as having a .33 CD. Audi has masterful engineering when it comes to putting efficiencies into eye catching design.
