Results 1 to 10 of 10
    Apr 26 2016
    US
    Valve cover removal problem Please help
    Im trying to repair my head gasket leak on a on a tsi engine and i am worried if i did something wrong, as my cams are looking weird. let me explain what i did:
    1-I removed my timing chain cover from the left side -
    2-i removed all the bolts on top of the valve cover and i notice that the cover was not moving.
    3-then i removed the vacuum pump from the right side and as soon i removed it the cover jumped a tiny inch up.
    4-then i just lifted up the cover and it came right off
    BUT
    5- when i removed the cover, both my cams look like they are elevated from the right side, what i mean by that is that they do not seat perfectly down on the engine.
    My question is did i damage my cams by not removing the timing chain?
    are the cams supposed to go up a bit when you remove the valve cover?
    Can i just install the valve cover back on and hope that the cover will push them back in place?
    I am very worried, and i would highly appreciate your help
    i will post pics for further understanding
    Thank you
    Apr 26 2016
    US
    Apr 26 2016
    US
    This is the little gap I am talking about after I removed the valve cover
    Apr 26 2016
    US
    Same pic different angle
    Apr 26 2016
    US
    bump anyone please that can help
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Why the newspaper in the head?
    Sent from my SM-N900V using Tapatalk
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Apr 26 2016
    US
    working in the backyard under a tree with an intense wind, I don't want leafs, dust, or any debri or anything else to fall in. Do you know why the cam is lifted on the right side?
    Nov 07 2018
    Jacksonville Florida
    I’m working on the same thing and saw that we have similar problems. Did you ever get a solution?
    Veteran Member Three Rings mr_milo's Avatar
    Oct 18 2013
    SF Bay Area, CA
    I found this thread as I will soon need to redo the gasket on my cover. From what I have read it seem the cover actually holds the cams in place as well. So if this is true, the pressure of the valves and the tension of the cam chain is causing the cams to lift on one side. Even though it's not ideal, it shouldn't be an issue as long as the cams / chain doesn't slip a tooth
    2014 A4 P+ 2.0TQMS
    2011 BMW 328i Convertible 6 Spd Manual - SOLD
    1999.5 A4 1.8TQMS - SOLD
    1986 4000CS Quattro 5 Spd Manual - SOLD
    Save the Manuals!
    Feb 15 2023
    Columbia sc
    So happen to have same situation. We’re you able to push cams back down with the installation of the valve cover?
