Originally Posted by
Barritia
I see a thread on here a few weeks ago going on about the stage 2 being more powerful due to the tune and not the downpipes on the S6 so has anyone just done the tune to see? I'm seriously considering stage 3 but don't want to currently get locked into a down pipe and if the downpipes on the S6 are the same as the RS would the down pipes In theory not be more than capable enough on the S6 with a stage 2 tune?
Educate me people.
A particular forum user is pushing that opinion rather strongly. Our testing disagrees. The pipes make results even with the Stage 1 software. Put the right software with them and it's even better. The pipes rather dramatically change the VE (volumetric efficiency) of the engine. Stage 2 software is designed to run properly with the changed VE. Running it without the pipes isn't going to work because the restriction is still present (lower VE).
As a rule, APR doesn't release anything that doesn't make provable power. I can go back through a list of products we've worked on that went to the bin because they didn't work.
The RS7 turbos are slightly laggier than the stock S6/S7 units, but it's not anything huge. It's certainly not like having GT28s or GT30s. Drive a stock RS6/RS7 and you'll get the same experience. It's very drivable and even more stupid fast when you want it to be.
The real question is, how far do you want to go?
