Results 1 to 10 of 10
    Mar 01 2013
    USA/VA
    Question shaking side to side while idleing.
    my 06 a4 2.0t Avant started shaking from side to side this morning after driving for 5 minutes. it only occurs while idling and if I give it just a little bit of gas it stops. I popped the hood and the motor is definitely moving more than it should.
    any ideas on what would cause this?
    • 06 Audi 2.0t Quattro Avant - Drop in K&N, Sony App Radio, 034 Snub Mount & Bracket, Carbon Fiber Interior Wrap - Sold
    • 01 Audi A4 1.8t AWM Quattro - AWE Boost Gauge, 18" Avus S4 Rims, 8000k HIDs, 3000K HID fog light mod, Pioneer Double DIN, Krauto Interior LED Kit - Sold
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    Do you have a check engine light? Also, you may want to inspect those motor mounts amigo.
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    check the mounts from the bottom, itll look like syrup is dripping out of them, they are maintenance items
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Mar 01 2013
    USA/VA
    Yea I was thinking it could be the motor mounts but wanted to get opinions. I'll check for the "syrup" and no to the check engine light miA4.
    Oct 02 2006
    Wadsworth,OH
    Typically if the motor is rocking that much you have a miss fire happening. You'd definitely see a check engine light if its persistent or even a flashing check engine light if its really bad.
    Worn motor mounts will definitely exaggerate the rocking.
    I'd start with an ECU scan and see what codes are getting logged.
    Jason
    Mar 01 2013
    USA/VA
    Jason
    I thought possible misfire as well but still no check engine after driving 30 miles (home to work). Do you know if the torque app will find anything if the CEL isn't on?
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by phatjames167 View Post
    I'm not too familiar with the Torque app, but it does mention it will detect DTC's, not sure if that includes internal codes as well but it may.
    Jason
    Mar 01 2013
    USA/VA
    no "syrup" but now I do have a CEL, the code is P0340, doing some searching now.
    Established Member Two Rings L'Audi's Avatar
    Apr 06 2016
    Long Island, NY
    Got this recently, very similar symptoms... Changed the cam position sensor and did a battery pull. Code never came back. Hope this helps.
    Mar 01 2013
    USA/VA
    Quote Originally Posted by L'Audi View Post
    It was the Cam Position Sensor, my clip is broken on it, and what I thought was weird is that I went out there and tried that sensor and it didn't work but when I went back out to try it, it started right away and was working correctly.
