Results 1 to 11 of 11
    Senior Member Two Rings Shaun Perry's Avatar
    Jan 02 2013
    San Ramon, CA
    Somehow my interior lights have reverse on/off function now.
    Just finished changing all the lights in the car to LED.
    Blew a fuse in the process, interior stopped working and power steering was gone.
    Replaced the correct fuse. Everything works now but I'm noticing when I push in on the map lights(both front and rear) that they turn off, when they should normally turn on. And when I push the map lights and they go to the out motion, that's when they turn on, when they should normally turn off.
    I tried leaving them in either in or out and took out the fuse and put it back in. No luck fixing it. I must have reversed something along the way.
    Thanks in advance.
    Established Member Two Rings TheLetterJay's Avatar
    Sep 26 2015
    ATL | NYC
    It looks correct to me.
    From my Moto X Pure using Tapatalk
    2018
    034 Mounts, Inserts, Rear Sway, Front Strut Brace | ECS Intake, FMIC | ABT H.A.S. | Forgestar
    Gone
    2014 S-Tronic
    Eurocode Alu Kreuz | CR-15 | 034Motorsport Transmission Mount, Strut Mounts, Rear Subframe Inserts | Solo-Werks | ECS Luft-Technik Intake, Rear Diff Mount Inserts
    Jan 02 2013
    San Ramon, CA
    Quote Originally Posted by TheLetterJay View Post
    So..
    Click and button is pushed out and the light is on?
    Click and button is pushed inward and the light is off?
    Why do I remember it being opposite before.
    And the interior led install from USP on their kit. The video shows opposite from how my car is acting.
    Sep 26 2015
    ATL | NYC
    My driver's and passenger's dome light are in the off position. Granted, I have a 2014.....but I believe that it's the same between B8 and B8.5
    2018
    Gone
    2014 S-Tronic
    Sep 26 2015
    ATL | NYC
    Quote Originally Posted by Shaun Perry View Post
    So..
    You got it!
    2018
    Gone
    2014 S-Tronic
    Jan 02 2013
    San Ramon, CA
    You got it!
    Thanks for that. Maybe I was overthinking it lol
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Lol dude your lights are correct.
    For the map lights: when the button is pushed "in" they turn off. When the button is more outward then they're turned on.
    With the dome light: Pressed to the right (the | symbol) they turn on. Pressed left (the O symbol) they turn off completely.
    With the switch in center position they work when the doors open/close.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    we got us a new grumpy 2.0
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Jan 02 2013
    San Ramon, CA
    Quote Originally Posted by DannyDeez View Post
    Lol thanks for clarifying Danny. I was probably just trippin for a moment. I swear in other cars the map lights operate in reverse fashion.
    Mar 21 2015
    Quote Originally Posted by Johnnycash View Post
    I think this guy is innocent, not intentional so far.
    Sep 11 2004
    16 Q5
    Westchester, NY
    No problem I was sitting in my car in my work parking lot reading your original post and I had to look up and actually test it myself. Otherwise I wouldn't be able to tell you which way was on or off either.
