2002 Audi S6 6spd
This car is awesome. If you have ever driven an S6 with the auto you know how fun they are. However, once it has been converted to a manual like this one it completely transforms the car. This car sounds great, runs great, and looks great! The car has 153,XXX miles on it. Here is what has been done in the last 6 months:
6spd conversion
Aluminum flywheel
RS4 clutch and pressure plate
JHM solid shifter linkage
Apikol rear diff mount
034 RS4 engine mounts
034 RS4 transmission mounts with spacers
New front axles
Coolant temp sensors
Powder coated A8 valve covers
Valve cover gaskets
Push in style coil packs
Camshaft cap seals
Rear main seal
SAI Delete 034
Electric fan kit
Timing belt, t-stat, water pump, tensioner
Serpantine belt and tensioner
Plastic coolant pipe inside oil cooler was replaced with the metal one
Power steering pump
Many, many hoses replaced with upgraded ones
Daz tuned
Other things the car has on it:
Hkis front and rear sway bars
Bilstein sport suspension
H&R springs
RS6 alcantara steering wheel
Solar panel
Magnaflow catback
Slotted rotors and new pads
Things I will sell in addition:
RS6 seats (not recaro style) - $1000
RNSE with bluetooth streaming - $900
Brembo 17z brakes - $1000
19in S4 Black Optic Rims - $1500
I'm asking $10.5k OBO. You will be hard pressed to find an C5 S6 in better shape with this much maintanence done. It is a clean title.
List Date: 4/26/2016
For more info, click here to view the original listing: 2002 Audi S6 6spd
On Sale For: $10,500.00
