Results 1 to 4 of 4
Thread: Oil Catch Can
    Jun 18 2015
    1995 BMW E34 540I
    Hartford, CT
    Oil Catch Can
    So I know there's quite a few articles about installing an oil catch can out there. I need a better step by step for installation, especially working around this tight of an engine bay. Any help of where exactly to route the hoses? Thanks
    Jul 04 2012
    Woodbridge, VA
    You put it between the pancake pcv valve and the air distribution piece on the spider hose.
    Implementation is up to you.
    All cans are different. Make sure to get an air oil separator. If you just put a can its pointless.
    Sep 09 2014
    Grand Rapids, Michigan
    I haven't actually run the car yet, o I can't vouch for the method but, I choose to completely remove the PCV valve from the equation. Plugged the hole in the intake manifold and everything. It was the simplest low maintenance method to still recirculate the majority of the air.
    The method I used is to just completely remove the spider hose, T in the valve cover vents with the crank case vent, run that combo of lines into the catch can and then run a line out of the catch can into the Y pipe. Let the N75 VTA (yes it's technically an "unmetered air leak"), and don't have the PCV valve/manifold vacuum source at idle. The argument against removing the PCV valve and manifold vacuum is that there won't be any way to pull the gasses from the motor at idle, but many people do the F hose delete on early style spider hoses and have no problems. I think the more realistic problem has to do with a 15 year old pancake valve and PCV valve letting too much pressure or vacuum by and blowing out top end seals. There isn't a more "right" or "wrong" way to do a PCV system. They'll all have their ups and downs. I wouldn't recommend a vent to atmosphere system though. They get smelly and leave oil residue everywhere. Just personal experience with a 1.8T.
    Veteran Member Four Rings treysgreen's Avatar
    Jan 03 2014
    02 A4 1.8t Quattro
    Atlanta
    http://s4mods.com/b5-oil-catch-can-install/
    Sent from my SM-N910T using Tapatalk
    02 A4 5spd 1.8T Quattro ///
    01 S4 6MT /// - SOLD
    Instagram - s4mods ///
    http://s4mods.com ///
