Results 1 to 20 of 20
    Apr 25 2016
    canada
    2001 awm Audi build.
    Hey guys just wondering if I can get some
    Input. I'm looking to get around 400awhp on my 2001 1.8t awm build and I was wondering what you guys have put in for the bottom end previously; ie, rods, bearings, Pistons, rings. Any input would be great thanks
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Dis my buddy
    Sent from my Jailbroken iPhone 6s 9.0.2 using Tapashit
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Apr 25 2016
    canada
    I'm also porting and polishing my awm head and putting race springs inconel sodium filled valves and titanium seats but running the stock cams and stock crank !
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Audi Dan View Post
    No you aren't, to any of that.
    Search dude. Do some reading.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Senior Member Two Rings Spectre1130's Avatar
    Jan 08 2012
    2015 VW GTI
    Colorado Springs, CO
    You really only need rods and pistons for the bottom end build for 400 hp.
    97 A4 1.8t: Reflect 650cc, T3 6063 turbo, turbo back exhaust & FMIC, top mount manifold, Apex lowering springs, 81.5mm bore, Supertech pistons, Eagle H beams
    Apr 25 2016
    canada
    Search which the head work or bottom end work ?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Spectre1130 View Post
    You don't even need pistons
    2000 S4- Working?
    Jan 08 2012
    2015 VW GTI
    Quote Originally Posted by redline380 View Post
    Word, didn't know that. I thought only the stock AEB pistons could handle that.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I'm saying you need to get your parts right. Inconel valves will be solid, not sodium filled. And I highly doubt there are any titanium seats available because titanium is most likely too hard for a seat.
    Like I said, spend the next couple weeks reading and digesting build threads and you will start to have a better picture of what is needed. If you have questions after that, come back.
    2000 S4- Working?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    All stock pistons are forged Mahle's. Only difference is that AEB pistons have 20mm wrist pins, AWM has 19mm. That 1mm difference will not make or break your build at all.
    2000 S4- Working?
    Jan 08 2012
    2015 VW GTI
    Thanks! I didn't know that. I was always under the impression only the AEB were forged pistons.
    Apr 25 2016
    canada
    Thanks man ! I'll read up
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Audi tt 225 are also I believe
    Apr 25 2016
    canada
    If I have an awm engine is it the 06a block? It's a 2001 and I've been trying to figure it out but all I'm getting is either 058 or 06a. Care to clarify ? Thanks!
    Jul 07 2009
    Socal/IE
    Its 06a
    Apr 25 2016
    canada
    Quote Originally Posted by tar View Post
    Its 06a
    Thank you
    Nov 07 2010
    South of Heaven
    The 058 block has an external coolant pump and the 06A has a timing belt driven coolant pump, that is the easiest way to tell the two apart. The cars with the 06A blocks have the best engine management for tuning and even though the 06A has smaller wrist pins they can make more power. Even the small port head is good unless you are moving a lot of air and can make your goal with simple upgrades. Researching is a great place to start because people have been tuning these motors for a long time so there is a lot of information out there. 400 AWHP cars are not always the easiest to drive in stop and go traffic so if this is your daily you may want to think about it. My car may be around 300 AWHP and nothing really starts to happen until around 3,000 rpm and it has a clutch that can handle the power so it is like a switch and can be a real pain to drive slowly. Once it is in boost it is all forgotten but out of boost can be a pain in traffic. You can get close to your mark with a good turbo/manifold, injectors, bigger intake system & intercooler, bigger exhaust, rods, and software so it is not hard to do. When you are replacing pistons, porting, cams, and solid valves you are really squeezing the hard to get power out of it which is really going to cost. Obviously start out with a motor that is in good shape and rebuild whatever needs rebuilding. When I put rods in mine the bores were all within spec so I just cleaned everything up and honed the block at home and then put new rings in it and didn't touch the top end. Once you have seen what other people have done to hit your mark you will have a much better idea what you want to invest in and get it done.
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    - 1991 Jetta G60 Coupe Syncro
    Apr 22 2007
    Riverbank, Ca
    All you need for 400whp is rods. The rest will be extra.
    This is what I have and its going to be similar power levels if not a bit higher.
    Engine: Audi AEB 1.8t Engine, Fully rebuilt, balanced rotating assembly and blueprinted, balanced and clearanced Intermediate shaft.
    Crankshaft: Stock/polished
    Rods: Scat Forged I beam rods
    Pistons: Stock
    Cams: Stock
    Valves: Stock intake, Stainless nitrite coated Supertech exhaust AEVN-1103
    Valve springs: Supertech high rpm valves SPRK-AUDI18
    Piston rings: Goetze 08-502900-00 (Factory stock)
    Head gasket: Elring Stock head gasket
    Rod bearings: 034 Dry film coated bearings 034-202-1008
    Crank bearings: 034 Dry film coated bearings 034-202-1000
    Intake Manifold: Stock
    Throttle Body: Stock AWM
    Exhaust Manifold: APR Iconel Stage 3 manifold
    Exhaust: 3" turbo back stainless steel w/ 2 stainless resonators
    Intercooler: 700hp air to water core.
    Turbo: Comp Turbo triple ball bearing CTB5356 10psi 275hp, 35psi 500+hp.
    Water pump: Davies Craig EWP150 w/ LCD controller
    Boost controller: Cortex EBC
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Apr 25 2016
    canada
    All the input the better I'm already starting to learn more from the other threads I have read and the posts on mine
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Read up on this B5-A4-Projects-amp-Builds
    and most of the people that commented have ''build/project'' threads if you look at them you should have everything you need.
    SOLD the GOINHAM A4 ---> GT2860 Project
