Is it safe to assume that the cable is broken (as a result the short circuit) and a front driver side sensor is required?
Are the front and rear sensors the same? As I have two spare rear sensors at home.
Code:
Address 11: Engine II Labels: 079-910-560-BNS2.lbl Control Module Part Number: 8E1 910 560 HW: 8E1 907 560 Component and/or Version: 4.2L V8/4V FSI ª0080 Software Coding: 01040003180F0160 Work Shop Code: WSC 00191 264 15243 VCID: E3CF3155224E191 1 Fault Found: 008756 - Oxygen (Lambda) Sensor B2 S1 P2234 - 004 - Signal Shorted to Heater Circuit - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 0 Fault Frequency: 1 Mileage: 121221 km Time Indication: 0 Freeze Frame: RPM: 855 /min Load: 18.4 % Speed: 9.0 km/h Temperature: 99.0°C Temperature: 26.0°C Absolute Pres.: 960.0 mbar Voltage: 13.716 V
