Results 1 to 2 of 2
    Veteran Member Four Rings 1FastS4.Com's Avatar
    Feb 19 2004
    Tesla Y Performance and Audi TTRS
    Neuspeed RSe52 Light Weight Wheel Satin Gun Metal and Tires Conti 275/35/18
    Wheels and Tires only have 1500 miles on them. Satin Gun Metal
    Tires are Coni sport D/W 275/35/18
    Black OEM lugs included.
    Introducing the all new RSe52 light weight wheels, the street 18-inch version of the 17-inch RSe05. Carrying the same concept from NEUSPEED's other wheel line ups, the RSe52 displays smooth and simple design lines giving the 'clean' and un-overbearing but yet complimentary to your European design Audi and Volkswagen vehicles.
    The RSe52, specifically in 18x9.0J, has a key feature; DEEP CONCAVE HUB which provides weight saving as well as depth to the aesthetic of the wheel.
    Each RSe52 is spec-ed specifically for the assigned vehicle, which translates to complete direct bolt-on fitment utilizing factory lug bolts, center caps, as well as tire pressure monitoring sensors (if applicable) ? No spacers!
    Weighing just a mere 21.8 lbs, The RSe52 wheels will enhance your driving experience cosmetically as well as performance by reducing the rotational mass or unsprung weight.
    Offset (E.T.): +40mm
    PCD (Bolt Pattern): 5-112
    Center Bore: 66.5mm
    Weight: 21.8 lbs.
    List Date: 4/25/2016
    For more info, click here to view the original listing: Neuspeed RSe52 Light Weight Wheel Satin Gun Metal and Tires Conti 275/35/18
    On Sale For: $1,000.00
    Mar 05 2012
    11 Q5 2.0T, 18 Q7 3.0T, 89 Foxbody!
    Bucks County, PA
    Pm sent
    2012 Q5 and 2018 Q7
