Results 1 to 12 of 12
    Nov 18 2014
    Jersey
    Need a little MMI help with my 2015. Can't get "Service Due!" message to go away...
    Kinda weird. I just did my 15k oil change and reset the interval...but when i start and cut the ignition i still get this message. Suggestions? Thanks in advance.
    2018 Jeep GC Trackhawk
    2022 Audi SQ7
    2017 R8 TT. 1370whp.
    2007 Porsche 911 Turbo...Bolt On's
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    You sure you really cleared it in Vagcom or Carista?
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    If the MMI is similar to the 15 A8 you can only clear the oil service indicator with the MMI. You need Vagcom or carista to clear the service indicator.
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Carista app with the right OBDII adapter. They have a single use charge to clear that.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Nov 18 2014
    Jersey
    So basically what I'm reading tells me that I can't clear it without spending money.....
    Aug 11 2015
    Alberta
    Yeah, but Carista and the dongle and the one time cost might be $20-30 and it can do other things.
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by Rez90 View Post
    Carista and an ODBII adapter can be had for <$50 and will do the clearing.
    I would see if you can meet someone from here locally to clear it.
    That, or the dealership might do it. However, it might be worth avoiding working with them since you are flashed.
    Nov 18 2014
    Jersey
    Can you send me links to said products? I'm not new to working on cars.... But when it comes to the electronics side I'm ignorant as shit
    Apr 05 2016
    Portland, OR
    http://www.caristaapp.com/
    Just FYI you don't need their adapters, you can find cheaper alternatives depending on your phone.
    Oh, and sign up for their beta program so you don't get charged for resetting the service indicator.
    Veteran Member Three Rings SouthernBoy's Avatar
    Jun 03 2014
    Virginia
    What about Vagcom? My cell phone is a basic flip-flop type and I have no intention of getting a newer phone (hardly ever carry it anyway).
    In the final seconds of your life, just before your killer is about to dispatch you to that great eternal darkness, what would you rather have in your hand? A cell phone or a gun?
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Quote Originally Posted by SouthernBoy View Post
    LOL, man how old are you like 100?
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    If your a do it yourself type then in the long run the Ross-tech cable is the way to go. the service warning and the E-Brake release will pay for the cable. The cable is good for testing and logging engine issues as well.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
