Results 1 to 22 of 22
    Established Member Two Rings Stan77's Avatar
    Nov 24 2014
    Russian Empire
    My little research on tyre fitment with 21x10,5 wheel on A7(C7)
    First of all, after 4 tries i finally found perfect tyre setup for 21x10,5 ET27
    If you're planning to throw some 21x10,5 on your A7, i bet you'll want some aggressive offset, and according to the fact, if you want stanced look and planning to ride something lower than stock height, than i can suppose ET27 is a max, otherwise you'll face alot of issues with rubbing. So i'm writing down some facts, that can be very useful
    1. Don't go more then ET27 if you're lowered
    2. Most of 285-30-21 will RUB, if your offset is <30 but it depends on manufacturer, so read p.4
    3. Forget about Runflat tyres in 275 and 285 sizes, in case of runflat technology it have insanely fat sidewalls, so overall even 275-30 tyre is wider that 285-30 non-runflat
    4. Check out exact wideness of tyre because it's very different with every manufacturer. For example, on my practice 285-30-21 P-Zero is 9-10mm wider than 285-30-21 PSS.
    5. Check out how tyre sits on the wheel, it must be stretched, if it's sitting straight, even with ET30 it will rub hard.
    6. If you're not quite sure about exact setup go with less agressive offset, for example ET32-35, you always can use spacers (personally i don't like it, but it's just me)
    My final setup is 21x10,5 ET27 with 275-30-21 Continental SportContact 5P, , no rubbing issues even on -30mm drop and fully loaded car. I must admit that Conti is less wide than PSS in same size.
    About pics. May'be cause my age doesn't meet requirements of "facebook generation" i'm not taking photo of everything so i don't have pics for every setup saved and don't expect super quality pics ) Most of 'em are made with old iphone in bad light conditions. And pics of final setup will come ASAP, i'll ask some pro photographer to make it =)
    285-30 PSS on 21x10,5 ET27 with 30mm lowering. Rubbing hard, but good for photo )
    Admit that 285 PSS is a little bit stretched on 10,5J. Here is how rubbing looks )
    Driveable height with PSS 285-30 Stock dynamic -5mm front, -10mm rear, still some rubbing on a hard cornering
    Difference between 275-30 PSS Runflat (left) and 285-30 PSS non runflat (right). Even unmounted tyre is wider
    Again, pics of the final setup coming soon, i've finished that quest just yesterday and i didn't even have a minute at daytime to take a photo, 'cause i don't want to impress you with pics in style "black man stealing coal at night" I'll update post later.
    A7 '13 TDI, Revo Technik chip, 300hp/640Hm. - SOLD
    A7 '15 TDI Facelift, Revo Technik stage2, Straight pipe cat-back, RS7 intake, Wagner FMIC, Cete ASC Module, Alcon 6-pot 380x32mm BBK - 310hp/690Hm - Current
    Jun 30 2012
    16 Lava Orange GT3 RS, 18 Nardo Grey RS3, 17 Panda Macan GTS, 91 C2 964, 16 F150 Lariat, 63 Impala
    Woodstock GA
    27 sounds aggressive. Don't buy PSS rubber on that setup.
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 24 2012
    2017 BMW X1
    Bay Area CA
    285/30/R21 PSS also rubs on 21x10.5 et30 if you lower your car too much. I just put that on over the weekends and they rubbed when I turned the wheel over the dip even in comfort mode with 30mm lowered. I found the lowest height I can go with that setup is 15mm from stock height in RS7 so I took the H&R box out since there is no point to use the box for the height that I can do with VagCom.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Nov 24 2014
    Russian Empire
    Quote Originally Posted by tonymission View Post
    Quote Originally Posted by VeryBadman View Post
    that's what i've said )
    Veteran Member Three Rings bonafyd's Avatar
    Nov 27 2008
    New Jerz
    Pics of said setups or this is just chit chatter
    Bagged C7.5 aka FISHBOWL
    |Airlift Bags|Accuair E-Level|Endo-CVT|I-Level|Aluminum Mirror covers|Aspherical Mirrors|Full 40% Ceramic Tint with Windshield|
    |AWE Touring Exhaust|RS7 Airbox|Flat Bottom Wheel|S7 Wheels|S-Line Sport Pkg|LED Headlamps|Frameless Mirror|
    |S6 Oem Trunk Spoiler|RS Pedals| RS Door Handles|S6 Diffuser|RS6 CT3 Carbon Fiber| RS6 Shift Knob|IE Intake|IE TCU Tune|
    Veteran Member Four Rings ntsantos's Avatar
    Dec 06 2015
    San Ramon, CA
    Has anyone tried running 275/35/21 on A7/S7? I think that's the oem size on the S8. It would be nice to have some extra meat on 21s.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Veteran Member Four Rings Sd76's Avatar
    Feb 01 2009
    Pa
    In for pics of set up
    Nov 24 2014
    Russian Empire
    Quote Originally Posted by bonafyd View Post
    sounds like a challenge ) well, updated the post a little bit
    Nov 24 2014
    Russian Empire
    Quote Originally Posted by ntsantos View Post
    It will look ugly IMHO, too much meat ) car will look like a carriage
    But it will fit if you're not extremely lowered and running agressive offset wheels
    265-35-21 looks like that. On a wide wheel it'll look little bit better but still
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by Stan77 View Post
    Got ya. I do like the look of the 30s, just fearing a harsher ride.
    Veteran Member Three Rings SlickMachine's Avatar
    Feb 21 2012
    2018 Ford Explorer Sport
    Aurora, CO
    I just ordered a set of AG M510's in Matte Antique Bronze from Jason at GetYourWheels for Stock height A7. Wheels are 21"x 10.5 et27, PSS 295/25/R21.
    Very low profile tire from what I've seen others running. Any thoughts? I'm sure the ride will be a bit more harsh than what I'm used to but its worth the look. Pictures to come when the are installed (5week build time).
    Senior Member Three Rings RSLRS71's Avatar
    Mar 03 2017
    18' SQ5 and WK2 SRT8 Jeep
    Castle Rock, CO
    thank you for the insight on this...curious about the DRC RS7's
    2017 RSL RS7 (1 of 3 stateside)
    Mods:
    Current: APR Stage II w/ HF DPs and KW H.A.S kit , Rotiform 3 piece SPF 21x10.5 wheels, Tag Motorsports Side marker delete and Badge blackout, ...
    Next: looking to be the quickest RS7! ;)
    Senior Member Three Rings 2wookies's Avatar
    Jun 03 2016
    Omaha NE
    Quote Originally Posted by SlickMachine View Post
    Are you lowering it while you wait for the wheels?
    Feb 21 2012
    Aurora, CO
    Quote Originally Posted by 2wookies View Post
    Negative. As great as it looks I just don't want to get into that on this car.
    Sent from my Nexus 6P using Audizine mobile app
    Jun 03 2016
    Omaha NE
    Hope it works out for you, and doesnt look like a 4x4.
    Feb 21 2012
    Aurora, CO
    Thanks for that. Really appreciate your well-wishes in that regard.
    May 17 2016
    Seal Beach, CA
    265/30/21 pss on 21x10.5 Sorry car is dirty.
    Feb 21 2012
    Aurora, CO
    Quote Originally Posted by Horti Kris View Post
    Stock ride height? That is waaay too stretched for me.
    May 17 2016
    Seal Beach, CA
    lowered on links. Probably way too stretched for most. Doesn't rub though, front or rear. lol.
    May 17 2016
    Seal Beach, CA
    Front wheel side view
    Feb 21 2012
    Aurora, CO
    Anyone know if 285/30/21 PSS et27 will rub on stock A7 ride height (non sport)? No air either, US model.
    Feb 21 2012
    Aurora, CO
    Stan... If you're still active here can you please post some pics of your final setup on the Conti 275/30? I'm having a hell of a time committing to that much stretch but I'm not sure I have a choice with the 27 offset. Would love to stick with pss285/30 on Eibach 1"drop.
