Decided to ditch the E55 project and keep the S4 and build it.
Car currently has K04s + Meth.
I'd like to get SRM K24's, E85 tune, rods, and 2.8 heads. Should be 600AWHP.
Questions:
First off - Is this a solid build?
Rods: Are scat good for this power level? I've seen conflicting ideas.
E85 Tune: Currently running upgraded 91 Octane fueling. What all is required beyond a new fuel pump, injectors and filter? Some say it needs new lines as well.
2.8 Heads: Is this worth the cost in added power?
Here's some of the spreadsheet I put together for it:
Category Upgrade Maker Model
Engine Turbos SRM K24
Engine Turbo Inlets SRM -
Cooling SMIC ER -
Engine Rods Scat 2.7t
Exhaust RS6 Downpipes SRM SRM
Engine 2.8 Heads OEM OEM
Engine Head Gaskets OEM OEM
Engine Valve Cover Gaskets OEM OEM
Engine Head Bolts OEM OEM
Fueling E85 Pump Walbro 450
Fueling E85 Injectors Bosch EV14
