Results 1 to 18 of 18
    Senior Member Two Rings RagtagXMASTER's Avatar
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Timing belt tension
    So i have a few threads so far with dumb problems but im trying to learn as much as possible so please excuse me if this sounds dumb.
    I have a timing belt on my car and i think its loose. It wiggles easily and can twist some were there is suppose to be no slack.
    The question is does this need to be tightened and if i do will it go out of time. Or if i dont tension it up will it be harmful.
    Thanks in advance guys sorry to keep bugging everyone with my dumb problems.
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    General rule of thumb, it should put up solid resistance when you twist it 90 degrees. Here's I.E.'s manual tensioner video, get it close to that lol
    https://youtu.be/nuBp85bzfnM
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    i uploaded a small clip of the play to youtube
    https://www.youtube.com/watch?v=ul5d...ature=youtu.be
    io can easily twist it but this just feels so loose, i could easily slide the belt off the cam gear by slowly wiggling off
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    I know I'm always sketched out when I feel my belt like you did in that video. I don't think I have that much, but I'll check tomorrow. Try the 90 degree thing rodgman talked about. The belt before the cam gear is gonna be tighter given that there isn't such a big distance between tensioner/pulley/cam and I choose to believe that's what matters :) In general it's just gonna have more play than you'd expect. It's possible your tensioner is toast and is fully compressed 100% of the time, but I'd doubt that.
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    The tensioner only has like 10k miles oem audi. But i cranked the bolt that holds the extra pulley on to hold it all in place if i loosen that a little i think it will snug up im just mervous about throwing it out of time or the belt jumping
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by RagtagXMASTER View Post
    ...I cranked the bolt that holds the extra pulley on to hold it all in place if i loosen that a little i think it will snug up
    I'm not certain what you are talking about here, but we should probably discuss this in more detail.
    We should probably start the discussion by determining what engine you have, so we know what timing parts we are dealing with. If you have a 2001 AWM, you will need to specify what the large roller looks like. There are 3 different versions.
    Version 1 (no adjustment):
    Version 2 (static adjustable eccentric):
    Version 3 (dynamic, spring loaded, auto adjuster for use without a hydraulic tensioner/damper)
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    I have an awm car mine looks just like version 2
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    https://www.ecstuning.com/ES1306812/ this is the one from my order i placed at ecs last january
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Also i am sorry about confusing this roller with the oem audi part. My orm audi one snapped at the auto adjust point from the pressure of the hdraulic tensioner. So this was its replacement. I totally forgot about that so this was oe aftermarket replacement.
    Jun 30 2008
    Erie, Pennsylvania
    Do you understand the workings of, and know how to properly adjust the eccentric? Did you successfully employ said knowledge to obtain a hydraulic tensioner protrusion of 6-10mm on install day?
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    I went to 5 mm. The original kit i purchased same version style had some instructions on setting to 5mm btween tensioner and roller arm. Once i reached that point i tightened it down.
    As for understanding it then i was not 100%. I really tightened that bolt down because i was more nervous on braking another hydraulic tensioner arm. I had a prior mtc tensioner and the push rod snapped in half and the roller and broken off. So i tried to make this roller as tight as possible to not move.
    Thanks for the help here walky
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    So i spun the motor by clicking the key and saw that the belt doesnt jump arpund or anything. And wen i put it at tdc its really nice and snug. I dont know why shortly after it gets so loose i have another video ill upload to youtube and show what im talking about
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Video of what im taking about with it at tdc. http://youtu.be/YmVtqBU4FPo
    Jan 12 2014
    Fargo, ND
    If I had to take a guess it almost seems like something is goofy with the eccentric. Nice and tight in one spot, but loose in another? I'd guess the eccentric pulley is spinning on its mount, causing high/low spots. I've been wrong before though!
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    if i lossen the bolt on it and spin the crank i am assuming it will give more tension. when it becomes too tight with the bolt still loose. will the roller arm force the tensioner rod back into the tensioner? its very well possible that i didnt torque that bolt correctly. i didnt use a torque wrench on it, i didn't have one at the time, i just recently purchased one when i did my timing chain tensioner.
    Jun 30 2008
    Erie, Pennsylvania
    The amount of tension (the tightness) of the belt is not adjustable. The only adjustment you have is the eccentric. That adjuster merely changes where the hydraulic unit is in it's travel. If you adjust the eccentric incorrectly, the hydraulic unit will not be in an ideal position. Too aggressive and the protrusion is too small. When the belt system gets hot, it may not have enough room to relax. Too lax on the adjustment and the hydraulic unit will be nearly fully extended and unable to extend further as the belt wears. The adjustment does not increase or decrease the tension (unless you are at the extremes - fully extended or fully compressed).
    The tension on the belt should be checked at TDC. At other positions there can be different forces on the belt. If the head is in a spot where it wants to spring forward, that force will pull against the tensioner and deposit slack on the front side of the belt where the tensioner can do nothing about it. This is normal. There is a possibility for this aspect to be exacerbated, however. The hydraulic unit could be very weak and far too easily overcome by the force from the cylinder head (valve springs).
    Bottom line, if you're paranoid about it, you should probably install the newest spring-loaded tensioner that does not have a hydraulic component or a tensioner arm. Version 3, above.
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Thanks for the input walky makes me feel much better about this. I like this car alot and put a lot of work into it so far. So wen i do my next timing belt in 40k miles ill go with whatever the latest revision is. I'll check on the belt regularly to make sure it is ok. But thanks a lot for all the help here
    Jun 30 2008
    Erie, Pennsylvania
    If you want the latest stuff, you'll have be proactive and look for it. Most of the resellers like ECS, Europa, etc are not listing or promoting the new non-hydraulic setup.
    Also, for the forum readership, this hot new stuff is for 2001 AWM and up only. Not applicable to AEB or ATW.
