Results 1 to 13 of 13
    Apr 15 2014
    Ottawa/Gatineau Canada
    Can domeone please confirm thr Stock B6 A4 1.8t AMB Cat part #
    My research shows 8E0 906 018
    But this does not seem right as google part search under that number gets me a ECU of some sort...
    what about 8E0 131 089 ?
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    I got my old one if you want it?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    2003 1.8T
    8D0 131 702 HP
    Also on the same Cat is 8D0 178 BE
    Aug 26 2005
    8E0 906 018 is an ECU base part number.
    Vorsprung durch Technik
    Apr 15 2014
    2003 1.8T
    8D0 131 702 HP
    Is the 8DO 178 BE an OEM part for the B6 A4?
    Dec 28 2006
    Western Maryland
    Both of those pictures came from the same catalytic converter that I removed from my car last year.
    Apr 15 2014
    I can not see the 2nd pic :(
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by Luxus Panzer View Post
    Both of the part numbers that I listed were on the same OEM catalytic converter that I replaced with a 034 HFC last year.
    Stamped above the Audi rings was 8D0 131 702 HP.
    Stamped below the Audi rings was 8D0 178 BE.
    So I assume they are both valid Audi OEM part numbers.
    Veteran Member Four Rings mauromj's Avatar
    Jul 23 2012
    Pullman, WA
    Ive got one if you want it. 70k miles.
    Apr 15 2014
    I am going to pick up a OEM Cat I found for a good price.
    The add says "brand new", however under further questions I am now told that it was installed for a E test and removed right after and a test pipe put on... less than 50K (KM) on it.
    How do I visually inspect a CAT to determine if it is in fact close to new??
    Established Member Two Rings dmanisgnarly's Avatar
    Nov 05 2014
    Supermotos & Sportbikes
    The East Coast, NC
    Look at the combs inside... if they are deteriorated or missing then its bad. I have a mint cat with less than 30,XXX miles on it. 60 Bucks shipped.
    2005 S4//K&N/Pod filter/Carbon MAF extension/APR Carbon NACA ram-air duct/JHM intake-mani spacers/Gutted piggies/Custom Catback/034 Motorsport billet engine mounts/19” Peelers/034 Snub/Neuspeed lowering springs/JHM stage 4 Kevlar clutch/Rallyarmor mudflaps/Rocketbunny V2 front diffuser/canards/HIDs/DRLs/LEDs/trailer hitch
    02' A4 1.8T Quattro
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    If the 1.8T has a metal support cat like the 3.0, you probably won't be able to tell how used it is. If it is ceramic, it would be easier to tell. Still no way to really determine if it's good or bad without installing it though.
    Sent from my DROID Turbo 2
