Results 1 to 28 of 28
Thread: OBD2 codes
    Junior Member Two Rings
    Jan 26 2016
    Auburn hills, MI
    Question OBD2 codes
    I recently(few months back) purchased a 2010 A4 Avant. Intermittently the car has rough idle, usually a few minutes after it has been started. At first I thought it was temperature related, it was february when I bought it. Now that it's warmed up outside I see no correlation to temperature, external or engine. whenever the "rough idle" symptoms occur, It is always slowing to a stop(engine is maybe 1400 rpms or less) or at a stop(1000-800 rpm). When this happens I will give a little gas and most of the time it will work itself out, If it doesn't I will kill the engine(if i'm in a safe place to do so) and wait a few minutes. Sometimes the waiting game works, sometimes it needs to get up in rpms.
    I scanned the car and got the codes below. And after Googling the codes I am seeing major timing issues. Most of the other engines that have the P0016 code have little to no ability to run at all, usually a timing idler or out of time. My car has only slight intermittent problems.
    I will be taking it to audi soon to have them look at it, but I wanted some input from all of you as to what may be causing it or what you suggest I check or do.
    I also am unsure of some of the non OBD2 codes(comments in italic), these may be VAG specific?
    OBD2 - confirmed:
    P0016 - Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor A
    OBD2 - pending:
    OBD2 - pending:
    P052A - Cold Start "A" Camshaft Position Timing Over-Advanced Bank 1
    OBD2 - permanent:
    Engine:
    P292C - Not sure what this is
    Engine:
    P1000 - Injector Cylinder 9 (N299), Circuit Malfunction - I assume one of the Injectors is going?
    Radio:
    02635 - Tuner not enabled / activated - No sirus XM radio
    Obtained with Carista 3.0 beta-12 for Android.
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Start shopping for a used cyl head that includes cams.
    2020 A4 allroad
    NH
    My thought is you have damaged cams and/or guides.
    No CEL? No EPC? How many miles on the car? If under 120k, injectors should be covered. Have Audi test continuity on the camshaft position sensor.
    Jan 26 2016
    Auburn hills, MI
    Quote Originally Posted by pierreb View Post
    Yes I do have a check engine light. Had EPC fault for about a day and it went away. 84k miles.
    2020 A4 allroad
    NH
    You could try a carbon clean if the continuity test is fine. Mine was intermittent. I think you need a new head though. Sorry.
    Jan 26 2016
    Auburn hills, MI
    like these?:
    http://www.ebay.com/itm/10-12-AUDI-A...BV07Qv&vxp=mtr
    http://www.ebay.com/itm/like/1620396...&ul_noapp=true
    Jan 26 2016
    Auburn hills, MI
    Carbon clean was exactly what I thought early on, Ive read up on Dans guide in the DIY section. However the codes make me think its worse than just that. I appreciate your honesty.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Crankshaft to cam shaft correlation codes means the the timing chain tensioner failed and the chain skipped a tooth or two. You need a new/new to you head, timing chain, and tensioner....
    2020 A4 allroad
    NH
    Yep, that's my thought as well.
    I got my new-to-me head with cams included and only 30k miles on it for $650 shipped.
    Like this one:
    http://www.ebay.com/itm/10-11-12-13-...O/391441128489
    That's not all you'll need though. If indeed the tensioner failed you'll also want new tensioner, chain, chain guides and cover.
    Jan 26 2016
    Auburn hills, MI
    Update, I scanned again last night and the two below went away:
    P292C
    This is the scan from last night:
    OBD2 - confirmed:
    OBD2 - permanent:
    Engine:
    Radio:
    Radio:
    03157 - Function Limitation because of Communication Failure
    Jan 26 2016
    Auburn hills, MI
    Quote Originally Posted by o1turbo30v View Post
    Audi thinks its the camshaft. Was that the reason you guys needed a complete new/new to you head? or was it something else?
    Jan 26 2016
    Auburn hills, MI
    Update: $2000 later audi dealer replaced the intake camshaft. Picked up last night. This morning the symptoms returned.
    What obligations are the dealer under to fix the issue?
    Im feeling like I just lit a bunch of money on fire.
    Aug 06 2012
    Parker, CO
    I would demand a refund of the money you laid out and find another dealership or independent Audi shop to get it fixed.
    - - - Updated - - -
    And.... If you paid with a credit card, call the company and dispute the charge
    2020 A4 allroad
    NH
    Well that's not good. I would've used the labor to just throw a used head on there instead. At least the new intake cam can be reused.
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    With all of those codes, you prolly jumped timing as the timing tensioner has failed. That's sad that the dealer didn't validate this (at least it doesn't sound like they did). I would call them up and ask "do you guys validate physical can timing?" Bring up to them the known issue with the timing tensioner.
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Jan 26 2016
    Auburn hills, MI
    Quote Originally Posted by Allowencer View Post
    I mentioned similar reports of tensioner failure to him, He later came back saying camshaft adjuster. Also that that it was part of the cam shaft and the whole thing had to be replaced($800 for that part).
    Jan 26 2016
    Auburn hills, MI
    I also mentioned to him needing the whole head replaced, he kinda scoffed at that and asked why. I didn't have a reason to give.
    Is the reason for replacing the whole head that is warped or cracked?
    2020 A4 allroad
    NH
    The reason in my view is that your tensioner caused an issue with timing and damaged the valve train. Changing one camshaft was only one possibility. There are guides, springs, valves and another cam in there to consider. A known good head + Chain job and you would've been set. Have you read the codes since the 'repair' ?
    Jun 12 2013
    If the clutch adjuster on the intake cam is bad, that can cause that code too. However, with your car being a 2010, has mileage, you really need to validate that the cam timing tensioner didn't fail and that physical timing is correct. This is a known issue. Only way to know for sure is to remove the upper and lower timing covers to verify.
    Build Thread
    2020 A4 allroad
    NH
    ^^^what he said.
    Jan 26 2016
    Auburn hills, MI
    OK It sounds like replacing with a known good head is cheaper than investigating and replacing all of the other components of the head.
    However, if you buy a used head you can run the risk of not getting a good working head. Then you would be out labor and have to return the head. Do you agree?
    Here are codes read after repair:
    OBD2 - confirmed:
    P0137 - O2 Sensor Circuit Low Voltage Bank 1 Sensor 2
    OBD2 - pending:
    P2096 - Post Catalyst Fuel Trim System Too Lean Bank 1
    OBD2 - pending:
    P2196 - O2 Sensor Signal Biased/Stuck Rich Bank 1 Sensor 1
    OBD2 - pending:
    OBD2 - permanent:
    OBD2 - permanent:
    Jan 26 2016
    Auburn hills, MI
    Update: I have gotten the car back from my audi dealer, and the car is really fixed this time(knock on wood) for no additional charge.
    The service report says a valve was bad.
    Thank you everyone for your help on this issue!
    Jun 12 2013
    "bad valve"?? Doesn't seem right.
    Can you take a pic of the service report and share what they replaced? I'm curious...
    Build Thread
    Jan 26 2016
    Auburn hills, MI
    Yeah ill snap a pic tonight
    Jun 12 2013
    Friendly reminder as I'm curious
    Build Thread
    Jan 26 2016
    Auburn hills, MI
    Sorry for the delay
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Sounds like a bad variable timing adjustment valve, on the front sprocket of the intake camshaft? What replacement part number is listed on the invoice?
    Jan 26 2016
    Auburn hills, MI
    I don't think they listed one.
