Results 1 to 40 of 67
    Sep 17 2005
    Fremont, California
    New Release: MQB Audi A3/S3 Quattro Rear Subframe Mount Insert Kit
    034Motorsport is pleased to present Billet Aluminum MQB Rear Subframe Mount Inserts for the MkVII Volkswagen Golf R & 8V Audi A3/S3 Quattro!
    MQB Audi/Volkswagen vehicles equipped with Haldex AWD use rubber rear subframe mounts which deflect under load, causing the rear end to feel vague and loose, as well as leading to less-than-optimal suspension geometry and increased understeer. These precision-machined billet aluminum inserts are designed to fill voids in the factory rear subframe mounts, and limit subframe movement without sacrificing ride quality or introducing any perceivable additional noise, vibration, or harshness into the cabin. The result is a more refined, connected driving experience, as well as improved effectiveness of aftermarket rear sway bar upgrades and suspension components.
    Designed to work in conjunction with the factory rubber mounts, this insert package was engineered using CAD software and thoroughly tested and refined to provide a significant improvement in handling performance and feel.
    These inserts were tested extensively by 034Motorsport and independent Audi/Volkswagen enthusiasts before release on new MQB chassis AWD vehicles. Installation is very simple, can be performed in under an hour, and is completely reversible.
    Features:
    • T6-6061 Billet Aluminum Construction
    • CNC-Machined In-House
    • Clear Anodized Finish for Durability
    • Engineered to Fill Voids In Factory Rear Subframe Mounts
    • Helps Maintain Proper Suspension Geometry When Cornering
    • Reduces Rear Subframe Movement During Launches & Acceleration
    • Improves Shifting Feel, Resulting in Crisper Shifts
    • Virtually No Additional NVH Transfer Inside Cabin
    • Easy, Straightforward Installation
    What's Included:
    • 034Motorsport Billet Aluminum MQB AWD Rear Subframe Insert - Front (Pair)
    • 034Motorsport Billet Aluminum MQB AWD Rear Subframe Insert - Rear (Pair)
    Installation Instructions:
    Fitment:
    • 2015 - Present Audi A3/S3 Quattro (8V - MQB)
    • 2015 - Present Volkswagen Golf R (MkVII - MQB)
    Please Note: The factory rear subframe bolts are torque-to-yield bolts, and we recommend replacing them when installing these inserts. A new set of four OEM bolts is available separately.
    Please feel free to send me a PM or email if you have any questions!
    Click Here to Order!
    You May Also Be Interested In:
    Adjustable 8V Audi A3/S3 Quattro Rear Sway Bar Upgrade
    8V Audi A3/S3 Dogbone Mount Insert
    Also Available At:
    Achtuning
    New German Performance
    GoodSpeed Performance
    Calgary Autoworks
    Eurotek Tuning
    PG Performance
    Quote Originally Posted by 034Motorsport View Post
    Features:
    What's Included:
    • PDF
    Fitment:
    Ordered today!
    Sent from my SM-G930W8 using Tapatalk
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by MuchoQuattro View Post
    Ordered today!
    Thank you for the order!
    Veteran Member Four Rings HurrayFive's Avatar
    Jul 21 2013
    Remote
    I just so happened to drop the S3 off at my tuning shop this morning for a DSG fluid flush and free upgrade to the latest APR revisions, they told me they had just got these inserts in stock and wanted to do an install on my car to see how they fit, so they didn't charge me any labor for them.
    Will update with first impressions after the drive home today
    '25 M8 Comp GC Frozen Tanzanite on Ivory/Night Blue - 11.0 @ 126 bone stock
    Senior Member Two Rings JohnnyUtah787's Avatar
    Oct 03 2015
    Illinois
    Quote Originally Posted by HurrayFive View Post
    Looking forward to your review!
    2015 Audi S3 - Glacier White, 19" Performance Package, B&O Sound System, LED Lighting Package, Black Optics grille, Black optics fog grilles, Black powder coated OEM exhuast tips, Satin black 19x8 ET45 Neuspeed RSe10 wheels with Continental ContiSportContact 5P tires (summer set-up), OEM 19x8 ET49 double 5-spoke wheels with Pirelli Winter Sottozero 3 tires (winter set-up), 15 mm ECS spacers all around, Emanuelle Design springs, 034 Motorsport dogbone mount insert
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    if they are anything like the inserts i had installed on my a4 b6, they are worth it!!! cant wait to hear more reviews.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Nov 13 2009
    the OC, SOCAL
    how many pieces in total are there:
    2 or 4?
    what are these supposed to help with?
    I have the dogbone mount and have to say I enjoy that mod. looking forward to understanding these mounts.
    I enjoy these innovations you guys are coming up with. keep it up. you guys will be rewarded with many orders from people.
    plus when are the engine mounts coming again?
    Mar 21 2015
    Quote Originally Posted by 949 View Post
    2 or 4?
    Read this
    https://store.034motorsport.com/docs...4-601-0032.pdf
    Jul 21 2013
    Remote
    Took the long way home to put the car through it's paces a little after the DSG flush, newest APR revisions (high-outout map picked up another 10hp & 20lb/ft tq), and the 034 inserts.
    All of it worked together very well, the revised power delivery and fresh-fluid-DSG-crispness was very nice. I could immediately feel the rear end just felt more "planted" though, more sure of itself. I couldn't detect any extra vibration in the cabin at any speed and I have BFI's engine, transmission, and dogbone mounts.
    I did a few soft launches (no LC) and this is definitely the difference, the rear end had a tendency to get this numbness if you floored it in 1st or did a hard launch and that's completely gone, it makes the car feel more confident in hard acceleration. Going to the next open track night on Friday the 6th if the weather holds, looking forward to seeing how the car feels with LC after these inserts!
    Sep 17 2005
    Fremont, California
    2 or 4?
    Good question! There are four inserts (two pairs) included in the kit. They are designed to limit movement of the rear subframe by acting as a mechanical limiter for the stock subframe bushings. The factory mounts allow for a substantial amount of movement under load (launches, acceleration, shifting, cornering) which results in a disconnected feeling from the rear differential, and affects suspension geometry as well.
    Our insert kit still allows for enough movement to minimize NVH transfer into the cabin, but limits the maximum vertical movement at each of the four corners to provide a more crisp, connected driving experience. You can see the difference in movement in the video below.
    We have more in the works for the MQB platform, which will be released in the coming months!
    Wow, that was some awesome timing! Glad to hear you could get them installed so quickly, and that you're enjoying the upgrade.
    Nov 13 2009
    the OC, SOCAL
    in the instruction it says to replace the bolts as these are stretch bolts. I am planning on seeing if can get ARP bolts to replace instead. what are the bolt specs so I can look for ARP ones.
    Sep 17 2005
    Fremont, California
    Unfortunately I don't have specs on the factory bolts handy, but the part number is N10715901. These bolts aren't problematic, and there won't be a benefit from replacing them with higher tensile strength hardware. Also, the collar on the bolts is meant to fit nicely into the recessed feature on our inserts, which may make it hard to find ARP hardware with the same fit.
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    I love your dogbone mount insert, so I ordered these as well.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Oct 30 2012
    Arizona
    Just placed my order as well based on feedback from HurrayFive. Going to order the BFI motor and trans mounts as well to get the drivetrain locked down.
    Jul 21 2013
    Remote
    Quote Originally Posted by A20V200 View Post
    Yeah buddy, get after it. Those BFI mounts in conjunction with the 034 inserts and the Eurcode rear chassis brace make the car feel RS+ territory in terms of structural rigidity and overall "rawness", without rattling your teeth out. Night & day compared to stock, enjoy!
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    Keep up the great work, love these little bits and pieces. If anyone needs a set, let us know!
    Greg
    Sep 17 2005
    Fremont, California
    Thank you for the continued orders! Any more reviews from A3 Quattro or S3 owners?
    Established Member Two Rings Stam4765's Avatar
    Mar 06 2015
    Southern NH
    getting them installed next friday along with your sway bar, ill post a brief review
    2015 Misano Red S3 | Eurodyne Stage 2 ECU/TCU | APR Intake | APR Turbo Muffler Delete | APR Catch Can | CTS Turbo Downpipe | 034 Rear Sway Bar | AirLift V2 Performace Air Ride Suspension
    Feb 14 2014
    Audi's
    Branford, CT
    A set we did on a MK7 last week. Awesome stuff.
    Apr 11 2012
    these are awesome, much less slop and no added NVH that I can tell. a must have if you're going for a more planted feel.
    Nov 13 2009
    the OC, SOCAL
    what is up next?
    Oct 03 2015
    Illinois
    Got mine in the mail last week. Hoping to install them soon. Just need to find the time.
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by will13k7 View Post
    Glad to hear you like them!
    what is up next?
    Next up is this, followed by some more suspension upgrades!
    Quote Originally Posted by JohnnyUtah787 View Post
    Looking forward to your impressions.
    Established Member Two Rings Dresevski's Avatar
    Jul 07 2010
    SF
    Impressed! I really like the look and simplicity. Will it be posted to the website soon?
    2015 S3 Daytona: stay tuned
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Dresevski View Post
    It will be next week!
    Nov 13 2009
    the OC, SOCAL
    still waiting on engine mounts.
    Mar 22 2016
    Las Vegas, NV
    +1
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Lusky View Post
    +1
    We're still testing them! Feel free to message me your name and email address so that I can add you to our waiting list.
    Mar 22 2016
    Las Vegas, NV
    PM Sent!
    Senior Member Two Rings FabianS's Avatar
    Jan 29 2015
    Calgary AB
    Just ordered a set seeing as I have the dogbone insert, and dig it.
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Any eta on when these will be shipped out, ordered with the dog bone and the dog bone shipped already
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Veteran Member Three Rings JGreen76's Avatar
    Jun 05 2008
    Houston, TX
    Putting in all 5 inserts tomorrow! Products look very nice, and lightweight.
    '21 RS5 Sportback-Tango Red - Black Optics Carbon Package
    '20 R8 Spyder Performance - Kemora Grey - Black Optics Carbon Package
    PAST:
    '21 SQ5 - Quantum Grey
    HIS: 2019 Glacier White TTRS Black Optics///HERS: 2019 Tango Red TTRS///2017 Macan GTS///2014 Q5 3.0T Glacier White with Black Optics///2015 S3..........:::Glacier White, APR Stg3::::.......///2013 MK2 TT Roadster///2007 B7 A4 S-Line 3.2
    IG: TwoCarGarage_HOU
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by FabianS View Post
    Quote Originally Posted by saxon View Post
    I'm very sorry for the delay with shipping your order! If you ordered with bolts, then we'll be contacting you via email shortly. New OEM stretch bolts are on backorder from Germany, which has delayed a number of orders. Unfortunately no ETA from the factory at this time.
    Quote Originally Posted by JGreen76 View Post
    Looking forward to hearing your impressions!
    Oct 16 2012
    pa
    i actually didnt order the bolts?
    Sep 17 2005
    Fremont, California
    PM sent!
    Sep 17 2005
    Fremont, California
    Thank you for the continued orders! These inserts are back in stock and ready to ship. The new factory bolts are still backordered, but will be available soon.
    Jan 29 2015
    Calgary AB
    Will you be holding back shipment of orders until the bolts are available again?
    Sep 17 2005
    Fremont, California
    If you have a pending order, yes. We've currently marked the bolts as out of stock on our website. If you'd liek us to partial ship a pending order, please send us an email with your order number at [email protected]
    Mar 22 2016
    Las Vegas, NV
    Tell me about this new bolt, do I need one I have had the dogbone for quite some town now.....
    Thanks in advance,
    Lusky
    Sep 17 2005
    Fremont, California
    Thanks in advance,
    Lusky
    You don't need to replace the stock bolt for the dogbone mount with our insert. These bolts are for the rear subframe mount insert. Hope that helps!
