Results 1 to 7 of 7
    Veteran Member Four Rings Deckdout2's Avatar
    Sep 13 2010
    2010 Audi B8S4 Ibis Prestige (SOLD), 2016 Audi C7.5 A6 Prestige (SOLD), 2004 Audi C5 A6 4.2 - 6spd
    Charlotte, NC
    AWE Non-Resonated Downpipes - Track vs Touring Swap Only Review
    So, I'm sure there's quite a few of you that have been wondering about the differences between the 2 systems, and I've come with a quick review for you after driving with both setups.
    I came from the APR RSC Exhaust, and then I deleted the Resonators in the Downpipes and rode with that for about 6mths. It was an amazing setup for those of you that were following my thread below.
    http://www.audizine.com/forum/showth...p-Snow-Day-Fun
    I was completely content with this setup but I was offered an amazing deal on a new AWE setup with Non-Resonated DP, I had to take up the offer just to test things for myself.
    This review is with the AWE Non-Resonated Downpipes as the common denominator, and the only part that changed were the rear sections which deemed to be a Track vs Touring setup. I am APR fully tuned with boltons with a stock DL501 DSG setup. I have not yet gone with the APR DSG tune but will at some point down the line.
    With that said, I initially ordered the Track setup with my Non-Res DP's, and impressions were amazing! I got exactly what I asked for, deep, throaty, increase in volume, and aggressive. I also got what I was afraid of, which was alot of induced drone. I was well aware of this going in, but this was my opportunity to see for myself how much in person and because not very many people have tried this aggressive of a setup. The usual is either Res DP/Track, or Stock DP/Track, or Non-Res DP/Track/6-spd. After 3 weeks of running the Track setup, the system finally broke in and was alot better than day 1 in the range of 2000k-3000k of driving. Around town and in Manual Mode, was a breeze and the best sounding exhaust I've heard to date. Cruising on the highway in top gear at about 70mph was barely comfortable with the drone.
    So keeping all that in mind before I move to the Touring review, if I had a 6-spd manual or was in all time manual mode with the DSG, drove primarily in the city, and if my girlfriend didn't ban my car completely until I changed out the exhaust I would have kept this setup. Or if I had Resonated or Stock DP's.
    AWE Non-Resonated Downpipes with the Touring Rear Section:
    OMG, night and day difference in terms of drone, even with the downpipes. There's an ever so slight amount, but nothing compared to having no resonators at all in the entire system except for the Center Resonator. This is completely girlfriend approved. I still get the same amount of grunt, deep tone I was looking for, and also the volume I wanted when I'm on it. I just no longer have headaches when driving anywhere at any speed or RPM.
    I'm confident that if things were reversed and I had Resonated or Stock Downpipes with the Track setup I would get the same results if not very similar as heard in some online videos.
    Let me add, that when I asked AWE for just the Touring rear section that they did not want to sell that section alone to me, I had to beg and plead with them. So they run a tight ship for sure, and the only way I got it was because I had just bought the entire setup a couple weeks before, and I was not returning the rears, but just buying the Touring rear so I spent a little more to be the test mule. With that said, my Track rear section is up for sale, and the link is below. You've read the reviews above, and I've tried to paint the best picture I can. Ask me any questions if you'd like and I'll answer them to the best of my subjective, unbiased opinion.
    Here's is some eye candy for you, and some sound clips, cause everyone likes those......This section is the only thing different between the Track and the Touring exhaust. All else is the same.
    AWE Non-Resonated DP's - Track Exhaust:
    AWE Non-Resonated DP's - Touring Exhaust:
    APR Stage II+ | APR TCU | APR Ultracharger | APR Dual Pulley | APR CPS | APR Open Intake | AWE Non-Res DP & Touring | H&R Coilovers | Hotchkis F/R Sways | Alu Kreuz Stabilizer Bar | USS F/R Endlinks | SPC Adj Arms | 034 Arms Kit | 20 x 9 +35 Rotor Reps | 255/30/20 V12 evo2 | RS6 Pedals Shifter | RS6 Shift Knob | Audison/Hertz Amp & Sub | RS4 Grill | Deval CF Splitter | Facelift Flat-Bottom | S6 Start/Stop Button | oCarbon Red CF | Relak v2.0 Paddles | ECS Stage 1 Brake Kit
    Dec 04 2015
    2014 B8.5 S4, 1989 Supra MKIII
    Nor-Cal
    Thanks for posting this, I've just ordered non res down-pipe for my touring exhaust and cant wait to hear it.
    Nice build.
    GIAC/AWE Stage 2, GIAC DSG Tune, Roc Euro Intake, Awe Exhaust, KW HAS Springs, Niche 20x10 on Michelin PSS, Enlaes Diffuser & Deck Lid
    Jul 14 2013
    British Columbia, Canada
    Thanks for the video, super informative and makes me comfortable knowing I will be running touring with non-res DP on a 6mt with minimal drone.
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
    Jan 05 2015
    Boston
    Switched from touring with resonated downpipes to touring with non-resonated downpipes a few months back and couldn't be happier. DSG.. drone is there, but not bad at all.
    |2011 B8 S4 | AWE Touring w/ Non-Res Downpipes | APR Stage 2 Tune | APR Stage 1+2 Intake | KW V1 Coilovers | 034 Rear Sway Bar/Endlinks | 034 Transmission Mount | Eurocode Alu Kreuz | Apikol Rear Diff Insert | 35% F1 Pinnacle Tint | Hardwired V1 | P3 Gauge | BFI Alcantara Shift Knob | RS Grille | Adam's Rotors w/ Akebono Pads | HRE FF01 19x9.5 et45 /w PS4S 255/35/19|
    Sep 06 2014
    Hong Kong
    hi there!! thx for ur post, i just wanna upgrade my exhaust system, what will u recommend? a AWE touring with non resonated downpipe??
    Jul 29 2016
    Edgewater, NJ
    Quote Originally Posted by Deckdout2 View Post
    Wow I am shocked. I would have totally thought that the touring exhaust would sound like the track and vice versa. I actually like the raspier exhaust note than the deep tone. Can't wait to have mine installed tomorrow.
    2016 Mythos Black A6 3.0T | Black Opts. package - AWE touring exhaust
    Sep 13 2010
    Charlotte, NC
    Quote Originally Posted by autobite View Post
    Ya, really happy with my Touring + Non-Res setup.
