Results 1 to 3 of 3
    Apr 25 2016
    Louisiana, USA
    2011 Q7 3.0 Temp gauge suddenly pegged high coolant alarm.
    First issue ever with my 11 Q7 3.0. I am the only owner. Temp gauge pegged high and alarmed with message to stop and turn off the engine. Well, hell ya, I stopped the engine. small amount of coolant coming from under right wheel well area. When i was able to check the coolant reservoir it appeared full. Started the car again with no issues or messages but as soon as i started to drive the gauge pegged and alarmed again. Had it towed to local dealer and now waiting.
    after some google research i discovered that the thermostat and or coolant pump are common issues for this motor; can anyone confirm this with a similar issue and does Audi have a recall for this crap? German engineering shouldn't about ruin my motor at 40,000 miles on an audi care serviced car. VERY ANNOYING. What is a reasonable repair cost?
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    s4s with the 3.0t engine, the thermostat has a high fail rate. Crappy audi design has it failing closed so the car over heats.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Apr 25 2016
    Louisiana, USA
    Unhappy
    Quote Originally Posted by cj'sQ7 View Post
    Dealer called.......stuck thermostat (just as I suspected) fluid was from relief valve. $1100.00
