Results 1 to 9 of 9
    May 11 2014
    United States
    Anyone with APR TCU Tune
    Hey guys just wanted to see with anyone that has the apr TCU tune(on a b8.5 gen) and wondering mainly of it ever shifts early in lunch control mode or the hybrid launch method. I currently have EPL TCU tune and really like it except I went to the track last weekend and it consistently shifted at around 6500, but when on the street it I ever just stomp on it, it goes all the way to 7100. And secondly, I'm sure everyone is aware of the delay in launch control between releasing the brake and the clutch engaging, apr says they minimize that but I would really like to get first hand experience to if it is a more instant launch once you release the pedal. Any info would be great. Thanks guys
    May 14 2015
    New York
    I had the APR tcu tune before switching to Epls tcu tune and I hoping Tony will be able to get the few kinks out but the APR tcu tunes launch control pulled way harder to the point where it would give me a head rush. I haven't experienced that with Epl it is much jerkier
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    I have EPL ECU and APR TCU... Love the Amax!!!
    May 11 2014
    United States
    Does it shift consistently at 7200 during launch control and how is the response once you release the brake pedal, is it immediate or is there still some delay?
    Veteran Member Three Rings Zaxon55's Avatar
    Mar 13 2014
    Centennial, CO
    Quote Originally Posted by GRUMPY-S4 View Post
    Do you have any issues running a APR TCU with another ECU tune? I always though that you needed to run the 2 together (or at least the performance was better when they were the same vendor)?
    2013 B8.5 - Moonlight Blue Metallic
    - VMR V710 19x9.5 -APR Dual Pulley -AWE Coldfront System -Eurocode Alu Kreuz -Front/Rear Sways and Endlinks -ST Coilovers -SPC Control Arms -034 Transmission Mount and Diff Mount -Roc Euro Intake -Porsche BBK with ECS Drilled/Slotted Rotors, SS Lines, Pads -CR-15 Upper Strut Tower Brace -AWE Touring Exhaust (102mm and stock downpipes) -Deval Diffuser, ECS front and rear spoilers.
    Nov 16 2015
    DFW
    Im not the only one running EPL and APR combo. No issues other than an over rev code, but Tony corrected that for me.
    Apr 11 2016
    Phoenix, Arizona
    I have the APR TCU tune, and I am wondering why it only shifts at 7200rpm in sport mode, but not in manual mode. I do have auto upshift on and I have the APR stage 2 ECU tune.
    Nov 16 2015
    DFW
    Quote Originally Posted by speedy0339 View Post
    I will have to try and confirm this.
    Apr 11 2016
    Phoenix, Arizona
    I went back to the shop and had them fix my tune. Apparently my Auto upshift was enabled in manual mode so it shifted at stock rpms. It now lets me shift at 7200 in manual mode.
