    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Sensen shocks for 2004 A6 Quattro 3.0
    Needed cheap replacement shocks for above car (lady is on a budget).
    Ordered the Sensen 3212-0181 for the rear, and 3213-0238 for the front.
    Obviously, the existing spring will be reused.
    But the parts are just a shock itself. Are mounts, spring seats, etc. to be removed from old struts and transferred over. Or in other words: can the old shock cartridges themselves be removed and replaced?
    I don't want to bring the car in and take the stuts out just to find out that what I have (Sensen shokcs) will not work and more/additional/other parts are needed.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Sep 11 2009
    NE
    Looks like you're the guinea pig on this one. How long do you think a chinese junk will last?
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by julex View Post
    I worry about that once/if they are installed.
    But likely last longer than the POS Germany made 3.0 (worst Audi engine EVER) that is in that ladies car; and the glories ZF 5HP19FLA will likely also crap out before that.
    05 Golf TDI
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    I'd recommend replacing the shock mount as well, it made the biggest difference on mine which were dried out and rotted.
    Although on mine at least the shock mount costs more than the shock itself.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Feb 20 2010
    Brighton, MI
    Back to the original question on hand: can the old SHOCK be just replaced with the new naked Sensen (don't even have the spring mount, which ALSO needs to be transferred).
    a) nakes shock
    b) shock with spring mounts
    c) complete strut
    Has someone done a 'naked shock' change using/transferring the other parts over?
    Has someone done Sensen shocks on the C5 chassis?
    http://www.carid.com/images/sensen/s.../3213-0238.jpg
    https://www.stockwiseauto.com/images.../MON/71331.jpg
    http://lgcdn.wolfautoparts.com/media...2_img_0074.jpg
    05 Golf TDI
