After reviewing many online options to supplement the OEM heat exchanger with another exchanger, I soon realized that you really can't fit too many exchangers above our crash bar that IMHO would make a significant impact in IAT's without replacing the entire heat exchanger with a larger one, similar to what you see in other kit, plus I dont' have the time to dedicate in researching it anymore but I do encourage others to try to go the custom route. With that being said, I will end up going to full AWE Coldfront w/ pump route; I like the idea of the pump being functional at idle speed, and also when the accessories are on without the engine needing to be on to circulate the coolant. Currently with the OEM unit, if I shut off the engine after a run, IAT's will creep up to 75C even after sitting for 15 minutes that I find it better to leave the engine on w/ the hood opened. Although I'm not 100% keen on a divorced system with the risk of running low on coolant w/o manually checking every so often, I do like the concept of being able to add ice cubes to cool down the coolant.
My question is, has anyone been able to log before/after of IAT's when adding ice cubes to gauge its effectiveness? I was thinking instead of running ice cubes, why not take a few icepacks to wrap around the reservoir as my understanding is that it does flow in/out of the reservoir? I searched but no luck on finding anything in regards to cooling the reservoir itself (would be neat to be able to run the A/C line through the reservoir though....
With that being said, anything that will help IAT's will be fine, particularly at the strips. Currently in mid 80's weather at idle, I see 50-53C, and once moving it moves down to about 47C. If I go WOT, it'll jump up to 85C by the end of 4th gear
