    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    RS4 (K04 frame) turbo on BEL
    I have APB based RS4 sized (housing) turbo to go on BEL engine (realized too late the mismatch).
    Can they be made to fit?
    Currently having a hard time to see how.
    I HAVE installed (big pita, some grinding) K03 APB on BEL car a couple of years ago.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Senior Member Two Rings frankwizzle's Avatar
    Oct 08 2008
    Derby City
    Just need DPs from an APB then it should bolt right up.
    Sent from my Nexus 5 using Tapatalk
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Yes, the manifolds themselves are the same between APB and BEL. The only difference are the [stock] turbo flanges and downpipes.
    So grab a set of aftermarket APB downpipes and you'll be golden.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Feb 20 2010
    Brighton, MI
    Can even bolt up the TURBO (not even close), interfernece with block everywhere. It seems the compressor size increase is creating the interference.
    Forget about downpipe not fitting.
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    Reclocked the compressor (was a bit off). Also: I had removed engine/tranny as complete unit with subframe, resting on cart i had built, supported at front subframe cross member and rear of tranny. That let to engine sitting on subframe, reducing the clearance beyond the normal conditions.
    Should be able to get install now.
    05 Golf TDI
