Results 1 to 12 of 12
    Senior Member Two Rings G-Ride's Avatar
    Dec 16 2008
    Imola 2003 A4 1.8TQ 5spd
    Melbourne Australia
    Shot clutch fork?
    I blew a clutch slave the other day, replaced it before looking inside the bell housing and consequently blew the second one..
    It looks pretty pitted and bent inwards causing the slave to overextend. I know it's supposed to have a small dimple for the slave rod to sit in. The first slave rod had worn through the plastic and pitted into the fork.
    What are peoples thoughts? There is 100,000 tough Km on the Sachs Race Engineering Dual Mass clutch kit. I think it's probably time for a new one.
    I'm thinking of extending the rod by 1/16 of an inch or so to get it down to the shop vs a flatbed.
    Imola Yellow '03 A4 Quattro 1.8T 5 Speed
    :: Motoza Performance Tuned on e85 ::
    : Frankenturbo F21-L : Bosch EV14 750cc Injectors : 3" MAF : Milltek Turbo Back Exhaust : AudiSport Suspection : ER FMIC : Sachs RE Clutch : TyrolSport Brake Kit : StopTech & Ferodo DS2500 : Goodridge SS Lines : Forge 008 : 034 SD Engine & Trans Mounts : Apikol Snub & Rear Diff Mount : Podi & VEI Digital Boost Gauge :
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    looks normal
    - - - Updated - - -
    its steel . that plastic pushrod isnt going to hurt it
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Dec 16 2008
    Melbourne Australia
    Quote Originally Posted by AudiTechS4 View Post
    looks normal
    - - - Updated - - -
    Thanks, I do realize its steel, but it was metal on metal for quite a long time which has grooved it in.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    It sure sounds similar to what happened to me from running a Sachs SS pressure plate and dual mass flywheel. After 80k miles of leg presses the clutch fork finally gave out.
    Along with your new clutch kit you are going to want to replace part numbers 5, 6, 7 and 8.
    Dec 16 2008
    Melbourne Australia
    Thanks for chiming in Old Guy, I tried to swing the bore scope the other way to have a look at the clutch fork all the way down but it wasn't working out.
    Have you moved to a single mass clutch?
    I've wanted to avoid single mass flywheels for quite some time, but given the amount of torque that is produced on E85, i'll probably have to consider it. The clutch/flywheel was vibrating when letting off 1st slowly from a standstill which made me think the flywheel had either separated or was royally stuffed. A few days later the first slave went, then I over night shipped a second one from Audi at Australian prices ($200 for a Sachs/Audi). Bled that in took it for a drive, however it still wasn't feeling great and the disengagement was an inch off. Pulled the car back into my drive way, and the last pedal press before I turned the ignition off the slave blew again. It'll be an expensive exercise..
    Dec 28 2006
    Western Maryland
    If your clutch engagement point has dropped to the floor that sure sounds like a bent fork or broken pivot block. Plus it explains the blown slave cylinder. I did the same thing. Pushed the end right out of the cylinder.
    I am currently running a Valeo single mass clutch kit. I have about 60k miles on it now and I am totally happy with it. I was pretty worried when I added the F21 as to whether it would work out but so far it has been fine.
    With that being said I think you may be putting out torque that is a bit beyond what it's capable of holding. A single mass kit should work OK for you but I think something rated a bit higher would be more appropriate.
    Dec 16 2008
    Melbourne Australia
    The clutch was certainly rated for it, had a max transmissible torque rating of 420nm/310 ft-lb. It's never slipped or let go, its been a beautiful and very smooth clutch setup. They do have a single mass version of it that I'll probably look at.
    http://www.sachsperformance.com/Sach...-Kit::101.html
    Dec 28 2006
    Western Maryland
    I was referring to the Valeo kit not being adequate for your setup.
    Dec 16 2008
    Melbourne Australia
    Ahh sure, missed that. Do you notice much vibration with the single mass vs the dual mass? I've always liked keeping the refinement there to be honest.
    I drove a car a few years back with an ECS 240mm single mass clutch kit and it was horrible. The engagement and overall feel was nasty.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by G-Ride View Post
    I believe the ECS kit contained a lightweight single mass flywheel. As long as you have a full weight single mass flywheel you will not experience all the low speed gear chatter that comes with a lightweight flywheel. Here were my impressions after I installed the Valeo kit with a single mass flywheel: Clicky click®
    Apr 03 2016
    Up North
    I say the fork looks like old guy's pictures when you pull it out. They are notorious for bending and cracking. I had the same thing you are experiencing happen on my Jetta. Blew a slave before pulling the trans only to find the fork pretzel'd. I'd recommend reinforcing your new fork. I took some .062" steel plate and my TIG and beefed it up good. No photos sorry, it went back in still hot from the welder as I had to make it to work the next morning...
    Dec 16 2008
    Melbourne Australia
    Quote Originally Posted by Human Garbage View Post
    Yeah, I've seen something similar from UROTuning
    http://www.urotuning.com/Clutch-Leve...erformance.htm
    Their symptoms of a bad clutch fork pretty much nail my experience before blowing a couple of slaves.
