Results 1 to 11 of 11
    Senior Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5
    LI, NY
    So i seem to have dug up a fossil
    Alright guys so i was looking for a DV and i found this thing in the b5 forums, I've found some information on it and its called the Hyperboost by a no longer existing company named Stratmosphere.
    Also the only posts i can find about these things are in 2000-2004ish and apparently back in the day everybody in the vw/audi community thought loudness was the defining factor of how good DVs were.
    I just wanted to find out if any of you guys are running these/can inform me a little bit about this thing..
    This is it
    [IMG][/IMG]
    [IMG][/IMG]
    14 B8.5 S4 6MT Current Daily
    01.5 B5 S4 6MT SOLD
    04 C5 A6 2.7T S-line SOLD
    02 B6 A4 1.8TQM DG Sport Package SOLD
    Motoza Stage 2, USP front end conversion w/ Cupra lip, S4 rear bumper, 18" BBS CH, OBX catback exhaust, Genesis 380cc injectors, PSI concepts test pipe, Stratmosphere Hyperboost DV, CX Racing FMIC, Forge TIP, S4 BBK, etc...
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    You found a little piece of treasure there. Nice quality DV, strat made good products while they were in business, they just tried to grow too fast, made some less than optimal money management decisions and ended up closing their doors in 2010ish
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Aug 26 2005
    What is the question?
    Vorsprung durch Technik
    Jun 21 2015
    LI, NY
    sorry, should of been a little more specific. I just wanted to know if they are quality pieces and also if they are adjustable at all through springs or anything like that.
    01.5 B5 S4 6MT SOLD
    Jan 24 2008
    Pennsylvania
    I ran one of those years ago in a 300hp Saab 900. Haven't seen one in years! I would do some tests on it given its age before you install it. Was a great DV in my application, but that part is 13 years old, I would definitely make sure it operates properly and doesn't leak.
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Aug 26 2005
    Quote Originally Posted by B6ayfour View Post
    That DV is a very good design, and like most, can be tuned using different springs and spring preload. The effect of a stiffer or lighter tension spring is different compared to spring preload.
    Jun 21 2015
    LI, NY
    it apprears in amazing condition for its age, tested it with my finger and it holds pressure. now that im thinking about it i read somewhere that it was adjustable but i really dont know how you would open/adjust this thing...
    01.5 B5 S4 6MT SOLD
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    This is the same DV I run, and its a great piece. To adjust and service it, unscrew the top - its threaded on. Lube the spring, add any shims or swap out the springs if you desire.
    Its has a good noise to it.
    Thinking about it, a lot of my mods have gone the way of the dinosaur. Ecode FMIC, Jeff Lee testpipe, Hyperboost DV, and although its not currently installed I have an OC.T. tip in the garage.
    2019 SQ5 Prestige
    Jun 21 2015
    LI, NY
    cool, this is great to know. i will definitely be installing that as soon as possible. Also on a side note i wanted to ask what you guys use to lube your DVs?
    01.5 B5 S4 6MT SOLD
    Apr 07 2011
    Mobil synthetic grease is what I've used.
    Jun 21 2015
    LI, NY
    So i installed my DV today and wow what can i say. I love it. First off the response is instant, it literally feels like as soon as my foot is off the throttle im at vacuum. Not like my last one which has an incredibly slow response, so slow that it would noticibly jerk the car. Noise is not as loud as i imagined but it is nice sounding. Now to try to somehow find different springs for this thing...
    01.5 B5 S4 6MT SOLD
