Results 1 to 7 of 7
Thread: Building 06 A4
    Active Member One Ring Hollywood986's Avatar
    Jun 26 2015
    06 Audi A4 Quattro 2.0T, 98 Subaru Legacy Outback Limited, 07 Honda Ridgeline, 02 Yamaha R1
    Iowa
    Building 06 A4
    I currently have run into the awesomeness of previous owners not maintaining their vehicles. I bought my 06 A4 Quattro Tipronic 2.0t last July, made it though the winter and was planing to do alot of run of the mill maintenance on it this summer when I could use my motorcycle as my means to get back and forth to work. Turns out my plans were spoiled when leaving my house a couple weeks ago. Pulled off a stop sign to a loud thud and jolt, car died and had to push it 3 blocks back to my house ( work out for the month lol). Started think timing belt since that was my plan as soon as Iowa winter ended. Pulled the inspection cover to find the timing belt to be perfectly fine. Car wouldn't start and acted as though no compression. Got it into the garage and started pulling HPFP, found the culprit to be the cam follower. Yet another part that was going to be replaced. This car has over 130k and i figured I would just do a full rebuild and upgrade everything for the most part. Since I now have smashed intake valves on cylinder 2, I will rebuild the top end and might as well replace with upgraded parts and once I have the head off I'm figuring I'll probably just pull the motor and finish by changing out the bottom end as well. Looking for ideas as well as sources for good parts. I need to know also if I can get someone to tell me if the turbo I have is stock? I have looked around and found that factory my car should push between 7 - 15 psi and i have an OBD link connected and boost reading from the dashboard display on there reads peaks almost 30psi and tapering down to about 24psi. Is this a misread from the ecu??? I don't know how to tell if it has a tune.. Any and all help is welcome. I plan to be building this project over the course of the year and it goes as far as replacing mount and full suspension. I am going for a moderate amount of power this is still an Automatic transmission. I'm not sure how much power the Tiptronic can take but I'm planning to build the internals on the motor for anything..
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Yikes.
    So you took the whole car apart without knowing why it wasn't starting? Did you pull any codes from it first? I doubt the cam follower was the culprit of it dying and not restarting.
    As for the turbo, I would look at the part number on the turbo first, and that will tell you. If everything else is stock, I would expect the turbo to be stock as well. Most people don't ONLY upgrade their turbo. 30PSI peek is high for our cars. I would look and see if the wastegate had been modded (they may have lengthened it too much).
    I would get the car back running and do some of those maintenance things you mentioned before worrying about upgrading. There's tons of info already on here to help with that.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    Quote Originally Posted by Hollywood986 View Post
    boost from the ECU reads absolute pressure in mBar. Need to subtract atmospheric to get boost pressure.
    2026 mBar - 1015 mBar (atmospheric) = 1010 mBar = 14.6 PSI boost
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
    Feb 15 2016
    Cambridge,Ontario
    I would say if you are sure the timing belt is fine but you smashed vales your problem is in the head ( ie tensioner failure etc. ) ,I am sure there are a lot of people driving around with the cam follower worn right though that don't even realize it. I doubt this is the direct case of your issue .. although may be indirect if pieces of cam follower are floating through your engine blocking oil passages and the like.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    take a look at google images and you should be to tell if you have a stock turbo or not....or just post a pic and we will tell you haha
    obv 30 psi way too high for a stock KO3 turbo but the N75 boost solenoid and or wastegate vacuum lines maybe torn or disconnected
    what device are you connecting to the OBDII port to read the psi?
    Sean
    The New
    B7---GIAC--BBS--DDM--JHM+S4Exhaust--StaSIS SS--034--AudiUP--USP--RedEBC--IE--DrakesVC#12--B7S4 Brakes--StopTech--GFB DV+--
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
    Established Member Two Rings pvltr_Chuck's Avatar
    May 05 2014
    Cedar Falls, Iowa
    Where in Iowa do you live? I too live in Iowa and have been looking for people who live here as well lol. Maybe if you're close I could offer some help if you need, especially with the general maintenance since I just did all of that to mine within the past few months.
    Daily - 08 Audi A4 6MT - Stage 2 JHM 91 octane - JHM short shifter - JHM test pipe - TT catback exhaust - ECS boost gauge - ECS snub mount
    Sold -- 06 Acura RSX-S 6MT
    Jun 26 2015
    Iowa
    I live in Mason City, IA. As for those who say I'm not sure as to what's wrong. I know that the timing is toast along with Intake valve on cylinder 2. The purpose for rebuild is that the cam follower broke, the piece that came off made its way into the timing chain on the back side of the head that matches the intake to the exhaust cam. It skipped the timing chain and all the intake valve made contact with pistons, only 2 seriously damaged were cylinder 2. But the all the pistons have markings showing that they where hit. I already know the cause of damage. I an now workin on whether it's worth my time to put $10k into this motor and upgrade turbo. I get my hands on a 4.2 with harness. This might be my new route. Only issue I have there is knowing if the tiptronic is the same from the 2.0t to the 4.2. If not I'll have to get a Trans as well.
