Hello my fellow tractor drivers
I have an issue with my B7 2.0 TDI. In South Africa the Le Mans was a special edition of the 2.0 TDI engines (125 kW) with the BRD engine code. I bought the car second hand, and thought that the low power below 1500 rpm was just a lag issue. I browsed the forum and it seemed like the Le Mans was known for its terrible lag. So I just accepted it.
In an attempt to reduce what I thought was just turbo lag, I had the DPF removed, did the downpipe and got a software upgrade. It did improve high end power but the "lag" was still terrible.
I had the turbo, clutch and flywheel replaced over the weekend. The technician that worked on my car also drives a Le Mans. After seeing what my car should be like I am quite upset. Especially keeping in mind that his Le Mans didn't have any of the upgrades that I have done on my car - and he doesn't have the same issue at low rpm.
It is definitely not turbo lag, there must be some other issue and the best that I can describe it is a dead spot. There is absolutely NO power until you go beyond 1500 rpm.
We had the following checked in an attempt to find the culprit for the dead spot:
*Overhaul the fuel pump
*Check pulley allignment
*Replace N75 solenoid
*Thoroughly test the injectors
*Replace the boost pressure sensor
*Check for vacuum leaks
*VNT actuator is brand new so the turbo spools at low rpm
When the boost pressure sensor is removed completely, the low end power seems to be fine (but you get a significant amount of overfueling).
This is as far as my fault-finding ability goes. Any one with similar experiences or advise will be much appreciated.
