Results 1 to 15 of 15
    Feb 06 2016
    Honolulu
    Overheating Problem
    Drove the car this evening.
    When I start going up a slight incline the temp starts to climb to about 3/4 on the temp gauge.
    So far it doesn't seem to go any higher.
    If I coast downhill then the temp will drop back down to the middle.
    But once the road levels off temp starts to climb back up to 3/4's.
    Searching this forum, it seems as most find their thermostats stuck open.
    I'm assuming mine is the rare one that is stuck closed but wanted to double check for feedback.
    Feb 24 2004
    Minneapolis
    Strongly suspect the stat.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Oct 24 2015
    Perth, WA
    Or fans. If you're going down hill more air, cooling the radiator.
    My respray thread
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by Okedokey View Post
    Pretty sure the airflow is the same unless he is actually driving faster downhill.
    I'm guessing it's a tstat issue or a possible bubble in the system.
    -Adam
    Feb 06 2016
    Honolulu
    Thanks for the feedback.
    The temp has been good for a long time so it's unlikely a bubble got into the system.
    I'm going to do the thermostat this coming weekend.
    Not looking forward to it but fortunately there's a lot of diy info.
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by rennwerkes View Post
    Just did that myself 2 weeks ago. Looks like a pain, but it's not....that is once you get the coolant drained. I hate that job.
    Feb 06 2016
    Honolulu
    Quote Originally Posted by mtroxel View Post
    Mind sharing how you drained your's?
    Did you just pull the bottom hose?
    Nov 12 2015
    Orange County
    I'd guess thermostat or waterpump or ECT sensor. I've had a stuck open thermostat, the engine will always hang around 1/4 to under 1/2 mark on the temp gauge, and you'll throw a check engine light on the freeway (never did on surface streets) The waterpump will either leak, of the plastic propeller blades will eventually detach themselves from the metal axle and spin freely regardless of rpm.
    If you change the waterpump, may as well do the timing belt/pulleys.
    Feb 24 2004
    Minneapolis
    I used the little valve in the bottom hose. Got a hose that goes over it, I save my coolant and pour it back in when I'm done. When you turn that valve 90˚ and you think it should be open….keep turning till it looks like it’s coming out of the hose. Then the flow starts. When that’s drained, I pull a hose off the heater core and blow in it to force coolant out of the block. When you’ve got it all that way, you lose very little coolant when you remove that stat.
    Feb 06 2016
    Honolulu
    Quote Originally Posted by zeitmorder View Post
    I'm really hoping it's not the water pump. :(
    Definitely will do the complete timing belt job if it is.
    Feb 06 2016
    Honolulu
    Got it!
    I heard from others that it's a PITA to open that valve?
    Active Member One Ring Rody_C's Avatar
    Mar 04 2016
    San Diego
    Check if the fans work, a easy way is turn on the a/c, if not start working at least one fan, the problem is the fan control module
    Feb 15 2016
    Cambridge,Ontario
    I just my stat yesterday it was the easiest stat I have done on any audi I have ever owned.
    just make sure you get the coolant pipe oring before you even start.
    having a "pick" to remove the rubber pipes from the fittings makes the job a breeze.
    like most things its about having the right tools before you even start.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 06 2016
    Honolulu
    Thanks, will check fans.
    But I suspect the thermostat since even at highway speeds the temperature doesn't come down and the lower radiator elbow isn't getting very hot.
    Feb 06 2016
    Honolulu
    Roger that.
    Already ordered one up.
