Results 1 to 11 of 11
    Veteran Member Four Rings ahcow's Avatar
    Apr 26 2010
    Toronto, Ontario
    LED around B&O speakers
    Those of you that have the LED rings around your B&O speakers, do all four of them light up? I realize that only my driver side door lights up and I find that odd. Either it's an odd design or I somehow got 3 faulty LED.
    New: 2016 S3, Sepang Blue, Sport Seats, S-tronic, Tecknik, LED
    Old: 2010 S4, Brilliant Black, Magma Red Nappa, S-tronic, Nav, Sports Differential
    Mods: Strat Intake, 35% Ceramic Tint, RS5 Pedals, BE GTS-AV, Hawk pads, Alu Kreuz, Vag-com, APR Exhaust
    Nov 26 2012
    2013 Q5, 2015 S3
    MD
    Only the fronts light up for me. Both sides.
    Sent from my SM-N920T using Tapatalk
    Registered Member One Ring IF1960's Avatar
    Feb 19 2016
    2014 RRS Supercharged 3.0
    Melbourne Australia
    Fronts (both sides) only on my 'vert as well...
    Ian
    Growing older is inevitable
    Growing up is optional
    Active Member One Ring Throcte's Avatar
    Apr 13 2016
    York, PA
    I'll take a look tonight, I know for sure both driver and passenger fronts light up on mine.
    Have you played with the light settings? I vaguely remember there being some kind of different light setting for 'front only' and 'all'.
    '15 S3 Prestige,
    '05 A4 Ultrasport, APR Stage 1+ / Sold
    Mar 13 2016
    San Jose, CA
    I just thought it was a reflective strip that was illuminated by the footwell LEDs. Huh.
    Mar 24 2016
    UK
    It's definately fronts only.
    I've looked into a retrofit on the rear, all the clipping points are there on the door casing for the LED unit but you cannot buy the light guide (fibre optic tube) separately from Audi.
    Active Member Two Rings AdrS3's Avatar
    Apr 19 2016
    Arizona
    Only the fronts for me. It is really strange since the rears look like they have the same light strip around it.
    Apr 13 2016
    York, PA
    Delayed follow up, fronts only for mine too
    '15 S3 Prestige,
    Active Member Two Rings moffe's Avatar
    Feb 07 2008
    Sweden
    Do you know what are the part numbers for the led strips for front? Wonder if it would be possible to do some DIY for the rear doors.
    Has any one tried to change the polarity on the b&o leds? I read on some forum that if you do it on the rings in the mug holder they turn red instead of white. :)
    Mar 24 2016
    UK
    There's no separate part number for the light guide in the front doors from what I can tell must come with the door pad ;o(
    Apr 26 2010
    Toronto, Ontario
    Thanks guys. Will get dealer to fix it at my first service.
