Results 1 to 7 of 7
    Junior Member One Ring
    Mar 30 2015
    92 Corrado, 99 A6Q,2000 A8Q,2008 A8L,03Subbie Outback(I know right?) 1915 Ford, 72 Mark IV Lincoln
    Pompano Beach
    Noise on back of engine. Chain Tesnioner or Charger ?
    I have a 2012 S4 with the exact same noise as this in the video. Anyone know the fix ? https://www.youtube.com/watch?v=i1Btag2tEpk
    Senior Member Two Rings IceSilverS4's Avatar
    Jan 06 2014
    2012 Audi S4, 2013 Tiguan R-Line
    Blainville, QC, Canada
    sound normal to me, coming from the high pressure pump connected to the camshaft for the direct injection (FSI). My jetta 2.0t, my tiguan 2.0t and my s4 have the same sound.
    The sound does get a little big more pronounce when the oil level is low, so topping it off reduces the sound a little bit.
    Sold - 2012 Audi S4 - Ice Silver - Magma Red
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Sounds normal to me. Maybe a little louder due to milage. But I wouldn't stress about it. What made you look for noise?
    Mar 30 2015
    Pompano Beach
    This is new and you hear it even inside the car . The oil was changed by someone else and the noise came afterward. The noise is on the back of the motor but hard to pinpoint from where. Not the HPFP or vacuum pump. I pulled the rear chain covers and found that the small guide rail at the top on the drivers side was cracked and hanging by a thread. So there are some pieces of it found in the pan. This is not the issue where the tensioners rattle on start up and goes away, this continues. I've read a tsb about a superseded tensioner with a stronger spring in the ram. I guess I will try that.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Quote Originally Posted by VAGBAHN View Post
    what oil was used, if sounds just came after oil change, seems oil is culprit!
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Aug 28 2013
    Winnipeg
    Sounds like any other s4 i have heared including my own!
    Sent from my SM-G925W8 using Tapatalk
    Jul 14 2013
    British Columbia, Canada
    Sounds normal me..
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
