Thread: Boost fading
    Established Member Two Rings 2000blk1.8t's Avatar
    Jan 26 2014
    Livingston
    Boost fading
    2003 1.8t stock. Normally runs good. Spikes 12-13 psi but usually ends up around 10 or 11 under power. Now, I hit the throttle and it takes off like a rocket for a quick second spiking 15 psi and fades to 5 or 6. Top end power is definitely down from usual.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Stock tuning shouldn't be hitting 15 psi. It sounds like your ECM is reading an overboost condition and putting you in soft limp mode.
    Check the hoses from the turbo to the N75 and from the N75 to the wastegate. I suspect you are going to find a crack or split in one of those hoses. If one of those hoses are leaking the N75 can't pass the full boost pressure to the wastegate and thus the overboost condition.
    Jan 26 2014
    Livingston
    Thanks. I'll check it out
    Jan 26 2014
    Livingston
    You were right! Found a tear in the line right next to the gate. I also pulled the codes and found an over boost code.
    Dec 28 2006
    Western Maryland
    Glad to hear that you got it sorted out!
