    Veteran Member Four Rings audibmi's Avatar
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    *SOLD* P3cars VIDI Vent Gauge Pre-installed B8.5 or B8
    P3 VIDI OBDII multigauge (white display, red bars)
    *SOLD*
    As new, includes all original packaging/box/manuals.
    Note: they retail for $579 for the preinstalled B8 vent, and not available pre-installed for B8.5 vent since you can't purchase vent alone without buying entire mmi panel.
    Unfortunately I am unable to run this gauge simultaneously with an OBDII splitter and a wireless Rosstech Hexnet or Valentine 1 Savvy, so my loss your gain.
    Preinstalled in B8.5 vent
    Complete package
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    Are the vents in a B8 and B8.5 the same? So if I remove the whole vent with a P3 from a B8 S4, can I just place it right in to a B8.5 S4? Thanks!
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    Quote Originally Posted by stereojorge View Post
    You theoretically could fit a B8 vent into a B8.5 dash but won't be able to illuminate the led in the knob.
    The B8.5 vent has a wire harness built into the vent (first photo) which plugs into a socket in the dash for illuminating the led in the knob.
    The B8 vent only has a socket on the vent which a wire harness from the dash plugs into.
    Also the knob on the B8.5 has chrome on the top and bottom whereas the B8 is black so it will not match the passenger side vent.
    Dec 27 2015
    orlando
    Interested in the b8 vent pm me or text me at 4072566805 nelson
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    all pm's replied.
