PSA: oem end links very well may not be beefy enough for use with hotchkis rear sway. My bar is interfering with my rear axles. It has rubbed material away from both the bar end at upper bushing and axle. Its almost as if the end link is too tall not to interfere with axle, but that is likely due to the fact my end links have now separated from the lower bushing. Wtf!?
At best the sway bar is compromised and useless, need new end links and my axles are still useable. Worst case, axles need replaced too.
This has been one big headache since getting the car back.
First pic shows the wear mark best. Thats passenger side. Driver side is exact same. And the plastic span on both end links is all chewed up. I am not that low either and drive on level 2 more often than not, but for auto kick down on high speed highway cruises. Wtf!!!!!!
