Results 1 to 3 of 3
    Dec 18 2008
    Virginia
    question on intake cam replacement and TDC
    Hi, Reading up on how to do this and I noticed that the manual says that none of the pistons should be at TDC. However, to take off the timing belt to do this, doesn't everything have to be set at TDC?
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Don't really understand your question, but when you put everything back together you want to make sure the crank is at tdc and the cams are properly timed.
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Active Member Four Rings martin0079's Avatar
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    Quote Originally Posted by mudd1011 View Post
    I did mine at TDC
