stealth boost gauge, replaces clock, expandable
This is made by ZT and is capable of the following add-ons:
- Exhaust Gas Temperature (EGT) K-Type thermocouple probe sensor
- Oil Temperature / Water Temperature Sensor
- Boost (MAP) Pressure Sensor
- Intake Air Temperature Sensor
- Intercooler Air Temperature Sensor
- Fuel Temperature Sensor
- Transmission Oil Temperature Sensor
- Gearbox Oil Temperature Sensor
- Exhaust Manifold Pressure Sensor
- Fuel Pressure Sensor
- Interior Temperature Sensor
- Outside Temperature Sensor
- Oil Pressure Sensor
- ZT AFR (Air Fuel Ratio) Wideband Controller Functionality
- Air Lift or Air Suspension Pressure Sensor
Replaces the clock (you can switch to clock function if need be). Matches the red lcd color.
Comes with computer, lcd for gauge cluster, boost controller, and air hose to tap into the fuel pressure reg line.
List Date: 4/23/2016
For more info, click here to view the original listing: stealth boost gauge, replaces clock, expandable
This item is no longer available.
