Results 1 to 13 of 13
    Established Member Two Rings ironman9's Avatar
    Jan 25 2016
    Brunei
    confusion on my A5
    Hello! So i have a 2013 Audi A5 coupe, but it is not quattro. I believe it is FWD. But a friend of mine told me that it is a RWD. Does Audi make RWD cars? And he said that my gearbox is DSG. I have the normal 8 speed tiptronic with drive select. Does that mean that I have DSG ? Also, he said that my car has electronic dampers given that I have the drive select as well it changes the steering stiffness and suspension. I know the steering stiffens when I change to dynamic, but I am not sure of the suspension. Does it change? I got my car used so I do not know what came with the car except for the exterior and interior (eg; alcantara sport seats and etc)
    Veteran Member Three Rings Audiforumuser's Avatar
    Mar 01 2010
    2010 A4 Avant S-line
    Saskatchewan
    If it's not Quattro it's fwd. You have the tiptronic 8 speed tranny and Audi drive select dampens your suspension.
    09 A5 S-line Monza Silver / Incurve IC-S10 20x10.5 / KW H.A.S.
    Mar 21 2015
    Call AoA and give them your vin and they can email you a digital copy of your original window sticker. That will have everything your car has listed on it.
    You can also use a vin decoder
    http://www.audiworld.com/forums/vindecoder.php
    Jan 25 2016
    Brunei
    ok thank you. Thats what I thought. Is the tiptronic a good gearbox? S tronic is better right? and tiptronic is not DSG right?
    - - - Updated - - -
    whats AoA? and where can i get my vin number? thanks for the info!
    Veteran Member Four Rings DreDay's Avatar
    Apr 25 2010
    Morris County, NJ
    Use the search feature my friend! AOA is Audi of America. Your is on the side panel of your driver side door. Call them up like @14S4GWM said and it should answer all your questions.
    CURRENT| C7.5 A7 TDI [MODS INCOMMING!] + 958 Cayenne Turbo
    PAST| Bagged MK1 R8| B8 SQ5| B8 S5| B6 S4| B6 A4| C5 Allroad| (2) T2 Touareg V8| Gen 2 Cayenne S
    NEXT| Another Stance Project
    Veteran Member Three Rings plat's Avatar
    Dec 19 2015
    GVRD, BC Canada
    Guys, the OP is from Brunei. Calling AOA won't help him even if he decides to spend for long distance.
    To the OP, contact your local Audi office and provide them with your VIN#. They should be able to tell you the car's full features and specs. As far as I know, if it is not Quattro, it is FWD.
    T.C.Y. MOTORS SDN BHD
    G/F, 1/F & 3/F Lot 59215
    Simpang 50, Jalan Dato Ratna
    Kg Kiarong
    BSB BE1318
    Negara Brunei Darussalam
    Tel: +673-2442333 Ext31
    Fax: +673-2422766
    E-mail: [email protected]
    If your local Audi office cannot or will not help you, look for the build sticker in the warranty booklet or in the spare tire wheel well in the trunk. It has a list of production codes printed on a white sticker that's around 6" x 8". Get the codes and plug it in this online decoder, VW & Audi PR Code Search. It will spit out a lot of your vehicle's installed features.
    Current: 2016 S5 in Sepang Blue with Technik Package.
    Mar 21 2015
    ^ Good catch plat!
    Jan 25 2016
    Brunei
    Quote Originally Posted by plat View Post
    Kg Kiarong
    BSB BE1318
    Fax: +673-2422766
    Dayummmm thank you so much! Really appreciate it bro! Im not gna call my Audi dealer because they're not helpful at all. Lol thank you! :)
    Sep 01 2012
    Edmonton
    RWD :) look under the car for the rear diff. Done.
    2018 RS3 Panther Black
    Established Member Two Rings Ixxe's Avatar
    Sep 29 2014
    Estonia
    Quote Originally Posted by WAF View Post
    Audi doesn't make rwd cars. Its awd or fwd.
    Sep 01 2012
    Edmonton
    Quote Originally Posted by Ixxe View Post
    Wow no kidding......... it was a smile at the RWD comment. If there is a rear diff its AWD if not its FWD. Ill post a pic next time so not to confuse some of you.
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    Unless Audi manufactures differently for Brunei, his ADS did not come with suspension dampening. You only get the steering and throttle adjustments.
    ....don't listen to your friend. He doesn't seem to know much about these cars if he thought an Audi was RWD.
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Jan 25 2016
    Brunei
    haha i know right. he said its a RWD, the gearbox goes all the way to the back blablabla. In my head i was like er no? Audi only makes FWD or AWD. I am die hard audi fan hahaha I just started working and only can afford a used A5 coupe. low mileage and good condition car and it was a good deal for me!
