Results 1 to 7 of 7
    Mar 28 2016
    2006 Maserati Coupe GT, 2004 Ram 2500 Diesel, 2012 VW Turbo Beetle, 2014 Yamaha FJR1300
    Auto engine off not working
    Another problem I found today is the engine off system stopped working. I usually have the button off. It
    was cool out and I had the windows open so I turned it on to see if I can live with it on. Turned off once and
    then stopped working. A white light with the system with and slash through it came up on the main dash between the
    gauges. I tried diffferent drive modes and no difference. Some times the light would go away not the engine never
    shut off. I tried different brake pressures and can feel the little switch/pressure point in the system but still nothing.
    Two electrical gremlins all in the same day and the car only has 2400 miles and I had it 2 weeks. The Sat. system
    was refusing to link up also. I am goign to go pull the car out again to verify. If its not working I will be taking it
    to the shop today.
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    I have found that mine rarely actually shuts off! Maybe due to conditions, not sure.
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Active Member Two Rings edwardg's Avatar
    Nov 02 2015
    spiders
    Bellevue WA
    Interesting. The system takes into account several different variables in deciding whether it will turn off, including engine temp and battery charge state IIRC. I actually had a fault for the system show up a couple days ago that cleared itself after the car sat overnight. Will be keeping an eye on it. 2016 S6.
    Since they implemented the system to pay attention to how hard the brake pedal is pressed, I actually leave it on and press a little harder to shutoff only when I'm at one of the really long red lights. Much more convenient than the all or nothing system in our other car.
    2016 S6
    Sep 28 2009
    suburb
    Can you enable auto stop on an S7 even if it doesn't have the button? Maybe for efficiency mode?
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Established Member Two Rings cdubya19's Avatar
    Feb 24 2015
    Nor Cal
    I know in S mode, the Auto start/stop won't activate no matter how hard you press the pedal. You'll get the "circle A" with a line across it. In D mode, I depends on factors like what Edwardg said. On hot days, I've had it activate for maybe 15 seconds despite having my foot firmly planted. It was hot out and AC was on.
    I do the exact same thing as Edwardg. Leave it on and press the pedal all the way down at long lights.
    The icon should go away though once you let go of the brake pedal. It should not still be lit in the instrument cluster.
    Sent from my SM-N920V using Tapatalk
    2016 S6 | Prestige | Glacier White | Sport Package | Driver Assist Package | Black Headliner | 20" Wheels | Carbon Inlays
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    If the car needs the A/C running it will override the start/stop. This is the main reason for the white A symbol with the line through it on the DIS. Switching to S mode or manusl will restart the engine and display the white symbol, as well.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Mar 28 2016
    I had the AC off and no fans going just the windows open, comfort mode and in D. It should have been shutting down but didn't seem to want too.
