Results 1 to 17 of 17
    Oct 02 2005
    The Moon
    Are there non oem fog lights for the B6 S4?
    I wanted to replace my fog lights, but over $400 for a set is absurd.
    After searching it seems B6,B7 A4, and B7 S4 and RS4 all use the same fog light at a much lower price. What gives?
    Has anyone tried to use or adapt these to work, or know of any other options?
    Thanks
    Veteran Member Four Rings Guitarmageddon's Avatar
    Oct 23 2010
    EARTH
    Oct 02 2005
    The Moon
    Quote Originally Posted by Guitarmageddon View Post
    Both of those are for cabriolet.
    Jan 29 2010
    north ga
    Quote Originally Posted by p3u View Post
    sadly this isn't the case. A4 and RS4 lights aren't compatible. The lights are the same but the mounting tabs are in different spots
    Dec 07 2009
    East Coast
    B6 A4 section has what you're looking for
    Forget the B8, keep the V8!
    Jun 07 2013
    West
    Always carry a fire extinguisher in the car.
    Oct 02 2005
    The Moon
    Quote Originally Posted by Mr.Wrong View Post
    Care to enlighten me good sir?
    Dec 07 2009
    East Coast
    Sure, enjoy:
    DIY-passat-projector-fog-light-HID-upgrade
    Veteran Member Three Rings IslandHydro's Avatar
    Nov 29 2008
    WA State
    B6 S4 Cabriolet
    Milltek exhaust w/ SW tips, H9 fogs (DRL), denison Ipod adapter.
    Debadged except the rings, TWM Leopard shift knob.
    TD Pro Race 1.2 Wheels, Continental Extreme Contact DWS.
    Oct 02 2005
    The Moon
    Those are for an A4. Thanks though.
    Senior Member Three Rings ImAudiHeree's Avatar
    Jun 30 2014
    Mercedes Metris
    Sacramento, CA
    Looks like B and R auto wrecking has them for $80 a side oem used. Also like others have posted they are b6 s4 only no other interchange.
    http://www.car-part.com/cgi-bin/sear...erPage=1&iKey=
    Oct 02 2005
    The Moon
    I should have stated I'm looking only for new. Mine are fine, just 12 years old and pitted.
    I went ahead and ordered some a4 fogs with the hope I can easily modify them to work in this application. I'll update once I find out and post comparisons.
    Jan 29 2010
    north ga
    good luck. I thought the same about a set of RS4 fogs I got. Unless you can swap the glass lens over then I don't think it's gonna work
    Oct 02 2005
    The Moon
    Quote Originally Posted by BCsniper View Post
    An update.
    Lights by no way close fit lol.
    However...
    I am happy to report by baking the fog lights I was able to remove the glass lens from the old and replace with the new.
    $22 later, S4 fogs looking like new!
    Jan 14 2009
    Audi's
    An update.
    However...
    Nice work!!!!! How hard were they to seal back up? You have any issues with moisture getting in...?
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Quote Originally Posted by Mr. Corey View Post
    From my experience with headlight if you get 3m black headlight glue it will be better than oem :) i did my ecodes last year and now 0 problems.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Jan 14 2009
    Audi's
    Quote Originally Posted by Lucca M View Post
    Nice nice!! Will look into it.
